Cam Experts Please (Degreeing my cam)
Need advice/help on degreeing my cam: What do I tell my engine builder to degree my cam in @ given 144+4 for this application?
2000 C5 402 TT 12 PSI
DURATION @ .050 INTAKE 218
DURATION @ .050 EXHAUST 228
VALVE LIFT INTAKE .562
VALVE LIFT EXHAUST .571
LOBE SEPARATION 114.0
INTAKE C/L 110.0
CAM ADVANCE 4
VALVE OPEN INTAKE 1-
VALVE OPEN EXHAUST 52
VALVE CLOSED INTAKE 39
VALVE CLOSED EXHAUST 4-
Thanks for you advice!
INTAKE C/L 110.0
CAM ADVANCE 4
It doesn't make a heckuva lot of difference either way. I've run it straight up for top-end, then later advanced it 4 deg to improve off-boost low-end torque. I like it better 4 deg advanced.
Mike
Mike
timing chain
no, it's 1 degree...Cloyes hex-a-just or actually plus or minus 6 degrees in 1 degree increments..cool eh??
Features:
Billet Steel, Induction Hardened Sprockets
Cloyes' Patented Hex-A-Just® allows for +/- six degrees adjustment
Premium Cloyes True® Roller Chain with .250” diameter rollers
3 Keyway Billet Crank Sprocket
All sets “Hand Matched” at factory to ensure accurate center distance
Also available in .005” and .010” undersize
http://www.cloyes.com/HighPerformanc...S/Default.aspx
Features:
