Homemade nitrogen push setup. Pics
Old 07-21-2008, 05:21 PM
Ping King's Avatar
Default Homemade nitrogen push setup. Pics
Ladies and Gents. I finally took some pictures of my nitrogen push setup.
Parts list:
114ci/4500 psi carbon fiber paintball tank with 1000 psi reg.
12 inch -4 nitrous line
NX 45degree valve with push port
High pressure check valve
Setup works nicely, instant bottle pressure, and it only cost me about 200 dollars in parts.
Attached Thumbnails Homemade nitrogen push setup. Pics-n20-1.jpg   Homemade nitrogen push setup. Pics-n20-2.jpg   Homemade nitrogen push setup. Pics-n20-3.jpg   Homemade nitrogen push setup. Pics-n20-4.jpg
Old 07-21-2008, 05:45 PM
jmill96Z's Avatar
Looks great. Any testing yet?
Old 07-21-2008, 05:48 PM
Z-RATED94's Avatar
Looks like you did a good job. When are you going to test it out?
Ping King's Avatar
yea works perfect!
Old 07-21-2008, 05:50 PM
Ping King's Avatar
200 rwhp shot works fine. I really didn't want to spend the money on a NANO, started to hate bottle heaters, and finally just old school hot rodded my way through a parts pile of things laying around.
Old 07-21-2008, 05:51 PM
jmill96Z's Avatar
So, what kind of track improvements have you seen with it?
Old 07-21-2008, 05:53 PM
Ping King's Avatar
havent taken it to the track lol. just street
Old 07-21-2008, 06:45 PM
DopeFedZ's Avatar
That's a pretty nice setup. I have a 100ci tank laying around with a adjustable reg. Might be time to put it to use.
Old 07-21-2008, 07:18 PM
VIPRETR2's Avatar
Wow, very nice setup. How many 10lb. bottle do you think you could push with that?
Larry
Old 07-21-2008, 07:31 PM
Ping King's Avatar
1 bottler per tank. works perfectly
Old 07-21-2008, 09:12 PM
Cam72aro's Avatar
That is pretty freaking cool man. The port on the side of the bottle valve goes directly into the bottle and the nitrogen forces all the nitrous out under pressure? How much does it cost to fill that nitrogen tank?
Old 07-21-2008, 10:10 PM
Ping King's Avatar
5 bucks to fill..its just a paintball tank
Old 07-22-2008, 12:04 AM
myfast70's Avatar
If you have a host Nitrogen tank, can you fill the small bottles as you would Nitrous?
Old 07-22-2008, 07:39 AM
Ping King's Avatar
nope..needs to be compressed. nitrogen isnt a cryogenic gas like nitrous is.
Old 07-22-2008, 07:47 AM
jmill96Z's Avatar
Did you adjust your jetting at all to curb the lean out on top?
Old 07-22-2008, 08:46 AM
myfast70's Avatar
If you were to keep the bottle pressure regulated down to 900-950 range, is there still a need to rejet the system?
Old 07-22-2008, 08:47 AM
jmill96Z's Avatar
It depends on the size of shot you are using, and the pressure drop you see on the big end without the push setup.
Old 07-22-2008, 10:49 AM
myfast70's Avatar
It would be 100-125 shot at most
Old 07-22-2008, 11:15 AM
DopdBrd's Avatar
Moar info, I just finished my own Standalone that cost me 200 bucks, it would be nice to do a Nitrogen set up for the same cost.
Old 07-22-2008, 11:49 AM
1QuickT-A's Avatar
I wonder if this would work on a 300 shot??
Quick Reply: Homemade nitrogen push setup. Pics
