Got my midwest Fab 9 in my Turbo TA
Old 07-26-2008, 09:06 PM
Sideways240sx's Avatar
Default Got my midwest Fab 9 in my Turbo TA
Alot of you followed my build. So here is the newest upgrades to the car.
The rear is a fab 9 from eric @ midwest chasis and performance. AMAZING!
If you are in the market for a rear end give him a shot, you will not regret it.
Anyways the rear consits of
Midwest chasis Fab 9
BackBrace
Spool
3.50 gear
35 Spline Axles
Longer 1/2 inch wheel studs
Black Powder Coat
Fill and drain plugs, and some other little goodies.
I also got a new chromoly torque arm, Chromoly rear sway, and new rear suspension.
The car is back on stock ls1 v8 springs, and competition engineering shocks. The car sits much meaner.
And the best part...... The pics.
let me know what you guys think.
Old 07-26-2008, 09:10 PM
Broke EF's Avatar
GAY!!!
Sean
Old 07-26-2008, 09:15 PM
veee8's Avatar
Looks great. How much $$$$??
How did you guys make out with the valve spring upgrade? Smoother upper rpm's?
Old 07-26-2008, 09:18 PM
smokinHawk's Avatar
looks good, cant wait till i get mine
Old 07-26-2008, 09:25 PM
Broke EF's Avatar
Yeah the valve springs did the trick, we have not had it back on a dyno, but its much better. Ill let chris chime in with the cost
Sean
Old 07-26-2008, 09:59 PM
Reject's Avatar
Originally Posted by Broke EF
GAY!!!
Sean
lol x2!!
nah loks good cant wait to finally start seeing the real numbers
Old 07-26-2008, 10:05 PM
Silenceinfullcolor's Avatar
Awesome rear.. and killer pic beside the nuclear tube thing.
Old 07-26-2008, 10:24 PM
Photochop's Avatar
Wow thats an awesome setup. I'm jealous!
Might consider the heater hose mod for the rear...sits a lil too raked out IMO
Old 07-26-2008, 10:29 PM
Broke EF's Avatar
It wont be so raked out looking with a 15" rim and a properly sized tire. Also when the front suspension gets done it will look alot more even. Remember thats just stock height in the back, and 1" down in the front, its not as crazy as it seems in pics.
Sean
Old 07-26-2008, 10:33 PM
Umm i believe what i got everything with a local pickup would be 3250 or so
with the powder coats, options, torque arm, dsl, sway. More shipped of coarse.
Yes. The car has yellow z06 springs, and tsp push rods. Pulls hard all the way to redline.
Chris
Old 07-26-2008, 10:37 PM
These rims will hold me over till winter with the new tires. Then hopefully a set of drag rims.
What broke ef said about the suspension. Just a stock ls1 spring in rear, with comp engineering shock. Cant believe thats stock ride height...
Personally though i think it looks kinda mean.
Chris
Old 07-26-2008, 10:52 PM
10 Second Moderator
Torkman15's Avatar
I think larger diameter axle tubes push the spring pads away from the axle centerline making the ride hight a little higher. Still looks good.
Old 07-26-2008, 11:18 PM
veee8's Avatar
I think it looks good. Stock the TA's have a taildragger look to them. This is a lot more aggressive looking.
Old 07-26-2008, 11:46 PM
XpEdItIoUs's Avatar
That looks Nice.
Old 07-27-2008, 08:38 AM
Websy21's Avatar
Very nice, this rear is on the top of my list if and when I get one!
Old 07-27-2008, 08:44 AM
deadmanTA's Avatar
Man your build is coming along great.
Old 07-27-2008, 09:09 AM
52172's Avatar
I just installed my rear last week its very very very nice. Mine weighs the same a the factory 10 bolt with the aluminum center section and tru trac and back brace.
Old 07-27-2008, 05:19 PM
veee8's Avatar
What kind of HP and abuse is the aluminum center section rated at?
Old 07-27-2008, 05:52 PM
T/A KID's Avatar
Great, mine will be here in about a 2 weeks, Eric said it will ship out sometime this week.
Old 07-27-2008, 06:26 PM
frcefed98's Avatar
Looks great, how long it take to get it??????
J
