MS3 in a DD
MS3 in a DD
what do you guys think about a ms3 for a DD I have a friend that is trying to get rid his he is trying to get smog legal and I can get it from him for pretty cheap I want to put it in my z but I'm scared it will torch my gas milege or kill me in stop and go traffic
I have it in my T/A and its not a bad daily driver. You lose a bit on the low end if your still running the factory gears in the rear. I raced an stock SS a while back from a first gear roll, and he stayed with me until i hit 3rd. After that i started to run away real quick, but with some 4.10s the race would have been over from the get go. I put down 386/367 to the wheels through the factory LS1 intake and with open headers. A tune is crucial with that cam, after the install the car wanted to die a few times. Oh and im an M6 what transmission you running?
-Joel
-Joel
it all really depends on the tune, gears will make quite a difference but as long a u have a good tune then u shouldnt have any big issues.....a little surging down low but nothing major
Its all in the tune. My buddy DD's his MS3 car in the summer months. The car drives nice and has very little surging. I believe he gets around 14 MPG with a 4000 stall and 100% city driving also.
I am talking to my buddy that has it he says he gets about 15 mpg
Item Detail
Name:
Texas Speed 233/239 Camshaft
Item#:
25-233239R2
TSP XS Series Camshaft:
233/239, .595"/.603" Camshaft With Your Choice of Lobe Seperation.
This camshaft features Comp Cams XER lobes! The XER lobes have been proven to make big horsepower & torque thanks to their aggressive ramp rates & healthy lift.
1900-6500 RPM Power Band; This is an excellent performance camshaft with a smooth idle! Custom tuning for automatic cars required
This camshaft typically gains approximately 50rwhp!
I think I might be better off just getting this I want a good bit of power but still cool to drive on a daily
Item Detail
Name:
Item#:
25-233239R2
i have the MS3 (look in sig for mods) car sounds absolutely basass. Drivability is just fine, i have 4.10's now...had 3.42...would would get gears for the car if you haven't, with or without a cam lol. It only surges under 2 k if your just coasting, but when u step on the gas at all, it runs stock-like, even with 3.42's it wasn't bad. You will loose low end, but past 2 grand with the 4.10's that thing flies, i recommend cam.
I seen a video on youtube with a 01 trans am on youtube with that cam that thing idled smooth and it sounded good though still sounded tough but didnt not buck and jerk
mti clear lid,k+n filter, slp maf,smooth bellows, pacesetter coated lt's, tsp catted "y",hooker cat back, 2800 yank,[313rwhp/317rwtq
It's a stalled auto that doesn't even have full bolt ons and has a catted y. Those numbers aren't that bad at all.
OP: you can make do with stock gears. I do. But they REALLY compliment the cam. After the cam, you should really start looking into doing gears.
we did a baseline dyno run before we installed my cam so we could compare numbers, on my m6 with full bolt ons and no tune, i only made 301......so if he doesnt have a tune then its definitely beleiveable!
I have a torquer v3 in my camaro with 373 gears and a 3800 converter and its not to bad. I wouldn't hesitate to drive it any where. It does have a little surge down low but its not bad at all. The gas mileage isn't the greatest (about 15 mpg) but if thats what your really worried about get a Honda.
