P1SC or D1SC
Old 07-31-2008, 03:24 PM
Chris'stransam's Avatar
Default P1SC or D1SC
Hear the deal! I am goning to bild a Lq4 block mild cam with L92 heads and L76 intake . The motor will be 9-1 .What supercharger would work good? P1sc or D1sc ? Allso car will be driven 2-3 times a week and run on pump gas
Old 07-31-2008, 04:20 PM
Customizing Director
MadIceV8's Avatar
Obviously the D1SC is a better unit, you can use a bigger pulley and make the same boost as a P1SC with a smaller pulley. And if your buying new its worth the $200 extra to get the D1. With that said there is nothing wrong with the P1SC, just a lower model.
Old 07-31-2008, 04:22 PM
krazy4's Avatar
D1SC, more efficient.
Old 07-31-2008, 04:32 PM
AFASTYZFR1's Avatar
D1SC
Old 07-31-2008, 04:46 PM
kwiksilverz28's Avatar
I double missed the opportunity to get the D1SC. One while ordering, and then the kit arrived with it. I was honest and traded it out. Damn. Double Damn. Should have listened to Bob and got it the first time, and definately should have played dumb and just installed it. Oh well, learn from me. It will cost me when I go big.
D1SC!
Old 07-31-2008, 05:37 PM
EPP
EPP's Avatar
D1SC!
No doubt! lol Bob
Old 07-31-2008, 07:14 PM
chieftransam's Avatar
D-1SC!!! That's what I'm getting as well! Just still trying to figure if I want to do a forged 346 D1 or 402 D1? Decision's ....lol. Yeah right I'm going 402 and D1 for now then move up to F1 or so.
Old 07-31-2008, 08:08 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Go with the D1SC straight out the gate. Pulley down as necessary.
Old 08-01-2008, 01:35 AM
One Bad Z's Avatar
My little p1sc does good for 10s on a stock cube/stock bottom end 346.
Anything larger than a 347 although should be running a D1, 370/402/403. Just an example not exact numbers but say you run 14lbs of boost with a p1sc on a 402 and make 600hp. The same 402 with a D1 can make the same power with only 5lbs of boost. The 402 with the D1 will always make more power easier.
If buying a brand new kit, a person would be dumb not to fork out the extra couple hundred to get the D1. But if you find a good used kit i wouldnt pass it up. I bought a complete p1sc procharger system with less than 3000 miles for under 2 grand and I have no complaints with it. Not building a record breaking car nor a 9 second street monster, just a car to have fun with and embarrass a few mustangs along the way.
Old 08-01-2008, 04:48 AM
EPP
EPP's Avatar
Thumbs up
Right on! Bob
Old 08-01-2008, 07:32 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Definitely the D1SC without a question for your setup
Keith
Old 08-03-2008, 01:47 PM
BLNLS1/RX7's Avatar
D1SC!
By being honest that shows you are agood Christan.
Old 08-03-2008, 03:10 PM
'Trust''s Avatar
You know my answer (sig).
Old 08-04-2008, 12:25 AM
One Bad Z's Avatar
BTW, that's still using a 6-rib pulley setup!!!!
Old 08-04-2008, 12:54 AM
Mr.Big's Avatar
Take one more step with the built motor and 9:1 compression... Go with the F1A!!! or F1C...
Don't get me wrong, My stock heads (except for springs) Stock LS2 short block (except for ECS blower cam) makes 713rwhp and 645rwtq @ only 9psi with a P1SC...
But the F1A and the F1C will be able to be pullied down for low boost, and then you have way more room to grow... Neither takes a ton of HP to rotate... If I can find a buyer for my P1, I'll be picking up an F1C the next day!!!
Just an idea...
I WISH someone would have suggested this to me... But with your built engine, and low compression, you have an even better reason to go this route up front than I did...
Quick Reply: P1SC or D1SC
