Nirous + N/A what is the CAMSHAFT
hey guys
my car will be
Wisco Pistons -3.2 Flat Bore 4.005 ( same stock LS2 )
COmpstar Connector the one in speed inc
headers Long tube 1 7/8
FAST 92
With ZEX WET SYSTEM
which is will be inside the FAST
patriot heads
Combustion Chamber: 59cc
Intake Runner: 227cc
Exhaust Runner: 70cc
Intake Valve: 2.055"
Exhaust Valve: 1.57"
Max. Valve Spring Lift: 0.650"
Heavy duty Oil Pump Melling
JP LS2 Single Roller Timing Chain Set
Underdrive Pulley SLP
Haltech intake
what should my CAMSHAFT be ? for N/A and Nirous Up to 250 ?
what horse power i should expect on dyno jet ?
my car will be
FAST 92
With ZEX WET SYSTEM
patriot heads
Haltech intake
i disagree
i disagree..maybe up to a 150 shot...175 or larger gol custom...the cam in my car has a 10 degree split and 0 overlap.....you dont want alot of overlap on a big shot....a 150 or smaller just a good na cam...
I agree. 250 or less=whatever cam you want. Not that you couldn't pick up a little more with a nitrous friendly cam, but how often will it be on the spray? If it's a nitrous drag car only, get a nitrous cam. If not, cam it for n/a. I see that Patrick G recommends the same as well, and there are probably not a lot of people on here with more cam knowledge. Just my 02.
i already had one my friend
from LG and talked to a guy there ,, with all my new package ,, he is intrested how much would i make in this CAMSHAFT N/A and also with nitrous
