2 Step w/o T-Brake??
Old 08-09-2008, 05:30 PM
calongo_SS's Avatar
Default 2 Step w/o T-Brake??
Just like the title says, anyone running a 2-step w/o a brake? Do you have it wired to the brake lights or ????
Any other suggestions for the 2 step other than the LPE piece? I don't even know if there's anything else available, it's the only one I know of that can be ordered.
Old 08-09-2008, 05:38 PM
crashly's Avatar
yep you can do that,
just use a switch 12 volt source without the tran solioinde ( spelling) hooked up..
it will act like a 3 step..
ash
Old 08-10-2008, 07:12 PM
calongo_SS's Avatar
Anybody having luck doing this? I'm worried the brakes won't hold if the car actually makes boost at the line and I'll be wishing I had just put a t-brake in while the trans was out.
Old 08-10-2008, 08:21 PM
Frost's Avatar
Originally Posted by calongo_SS
.... I'm worried the brakes won't hold if the car actually makes boost at the line and I'll be wishing I had just put a t-brake in while the trans was out.
this will almost certainly be the case.
Old 02-27-2009, 09:40 PM
calongo_SS's Avatar
Thought I would update this in case anyone stumbles across it.
I went with the LPE 2 step with the brake lights wired in series with a toggle switch for activation.
First test - it builds 4 psi almost instantly and slowly climbs to 5 after a couple seconds, I might be able to get another pound but I don't plan on waiting 15 seconds for another psi. This is at 3000 rpms. No timing retard, no adjustments in the tune, a/f is about 11.5, methanol just barely starting to spray.
It annihilates the tires on the street, I hope it'll stick on the track!
This is on a 346, APS twins, 3600 PI converter in a 4L80.
Old 02-27-2009, 10:28 PM
Silver_TransAm's Avatar
So the brakes hold it at 4-5psi?
What stall do you have?
Old 02-27-2009, 10:53 PM
calongo_SS's Avatar
yes, the brakes hold 4-5 psi. Precision 3600
Old 02-27-2009, 11:18 PM
crf538's Avatar
i was just going to post this same question...hope it works out as well with my py3400
Old 02-27-2009, 11:39 PM
hope it works on my 3k stall. I wonder how fast it would build boost if you tinkered with it.
I am trying to get at least a couple psi with my rear mount doing it this way.
Quick Reply: 2 Step w/o T-Brake??
