3 bar map
3 bar map
ok now having brain fart. tried search and want to see how people have installed thier 3 bar maps?
do you leave stock one in?
and tie into another vacuum source?
thanks in advance.
thanks in advance.
Courtesy of MM This is what he told me to do for installing my FAST 3 Bar MAP Sensor. Just run a small tube from this to the sensor
http://richmondperformancemusclecars.../original.aspx
Is this a direct plug and play for an LS6? Sorry, don't know the difference between the back of an LS2 vice an LS6 which I have. I was under the impression that they are almost identical?
That 3-bar sensor uses this connector: http://www.lsxtune.com/shop/product_...roducts_id/464
The stock MAP sensor uses this connector:
http://www.lsxtune.com/shop/product_...roducts_id/750
I make a convo harness that plugs into the OE connector on the harness and will plug into this style of 2 and 3 bar MAP sensor.
http://www.lsxtune.com/shop/product_...roducts_id/781
ok great!!
one more question lol
are the pins in correct locations too?
just keep them in order? i have the plug for teh 3 bar. was just gonna cut the wires and put new plug on.
i have
grey
light green
black
the plug is labeled ABC
would i assume Grey=A light Green=B Black= C
thanks for the info!!
i have
grey
light green
black
ok great!!
i have
grey
light green
black
i have
grey
light green
black
On the 3 bar, you should have,
A-Black
B-Green
C-Grey
