Which Fuel pump to use with STS Turbo?
Hey i'm thinkin of buyin an sts kit. its going to come with the 42lb injectors and everything else i need except for the fuel pump. which one should i get? could i get some suggestions plz?
thanks,
Drew
thanks,
Drew
Go with the dual pump setup, you will be thankful. I ran a single with 60# injectors, and was running out of pump at 8 psi. Then I had to pull it all again to add the second pump. With a turbo setup, you can't really overdue your fuel setup.
