Key on power source, 10ga OJ wire?
Old 08-25-2008, 08:24 AM
Cthulu's Avatar
Default Key on power source, 10ga OJ wire?
I have an 02 ws6 and am looking for a key on power source for my nitrous relays, I found a few threads suggesting a large 10 gauge unfused orange wire that only has power at key on is "where it's at!!!" and that it should be under the drive side dash...
Well I took apart the drivers side dash and poked around a bunch and couldn't find it :-(
what is it wired to?
I just need to splice into it so I can run power to my relays that power the solenoids.
Thanks
-Cthulu
Old 08-25-2008, 09:01 AM
Nick@HSW's Avatar
There are a few different places you can tap into for power. Look for the pink wires as they are 12+ keyed. I usually just do one of the add-a-fuse connectors in the fuse panel. This way you're not over extending the use of any one circuit. You can get them at most local part stores and they are made by Little Fuse I believe.
Nick
Old 08-25-2008, 12:40 PM
habeba86's Avatar
Orange is acc. pink is ignition.....I would use pink also..since it doesnt turn off when your cranking the car over. The wires run up to the ignition harness.
Old 08-26-2008, 05:15 AM
Cthulu's Avatar
Yeah, i'm using the pink off the traction control to power my switches. But the other is going to be responsible for powering dual inline nitrous solenoids( around 20 amps?) that's a decent amount of amperage for a smaller gauge wire, this is why I was excited about the 10ga oj wire I kept hearing abou :-)
Old 08-26-2008, 04:17 PM
Cthulu's Avatar
I have my relay inside my car and two 14gauge wires from the relay going to the noids..I don't have a power source for the relay though...
I've searched all over, it looks like everyone powers their noids off the engine bay stuff...is there not good switched power source under the dash?!?!
Old 08-26-2008, 05:58 PM
Cthulu's Avatar
52 view for the lose, someone has to power their relays from under the dash like me.
(I guess they aren't powered yet technically)
Old 08-26-2008, 07:54 PM
Cthulu's Avatar
5$ through paypal to the first person to post a pic of the 10ga ignition wire under the drivers side dash.
seriously. I need this for tomorrow, 5$ paypal first post with pic.
Old 08-26-2008, 09:08 PM
bad6as's Avatar
Old 08-26-2008, 10:01 PM
Cthulu's Avatar
harhar
That's not it, that line separates it's just shielding for like 4 other lines.
:-( some other post I found in the past said it was under the drivers side
Bets are off, found this.
"It's fairly easy. You'll find a bolt holding the fuse panel in place on the dash. Remove the bolt so you can move the fuse panel enough to be able to get your wire from under the dash (behind the panel) around the edge to the front. Put a spade (flat) connector on the end of your wire and plug it into the accessory port you want to use. Then just put the bolt back in to reattach the fuse panel."
So, even though only a 15amp maybe I can find a way to make it 30, not sure if it's just swapping out the fuse or what.
Old 08-27-2008, 03:19 PM
jmill96Z's Avatar
That's the way mine is wired (to the fuse panel). IMHO it looks like garbage, but it works.
Old 08-28-2008, 07:42 PM
NHRATA01's Avatar
LS1Tech 20 Year Member
Personally I ran the noid power directly off the battery to the high current side of the relay (with an inline fuse, think I put in a 30A). Then just put a tap on one of the pink lines to run the switch wired to the low current side.
Old 08-29-2008, 07:06 AM
RyanA's Avatar
If you want a 10 gauge power wire on the driver side, use the pink as previously stated. It's located right at the ignition switch on top of the column. You can usually trace the harness until you find a spot you want to tap into it. I would not use orange as the solenoids would also have power in the accessory position. The pink is only powered when you have the key in the forward position.
Here is the ignition switch pulled down from the column (you don't need to do this, I had to replace the ignition switch in the wife's convertible). You can see the wires that are being spoken of.
Ryan
Old 08-30-2008, 12:18 PM
RyanA's Avatar
So what's the word? Did you find the wire?
Quick Reply: Key on power source, 10ga OJ wire?
