how to window switch with ltcc coil setup??
Does anybody here know how to hook up a window switch to a the ltcc coil setup, i tryed emailing bob but did not get a responce any help would be greatly apricated.
well i havent picked a window switch to hook up yet because i dont know what will or wont work. I am looking for something i can lock out of first gear. i have read that harris speed works is coming out with a new window switch?
https://ls1tech.com/forums/nitrous-oxide/969326-new-microedge-nitrous-controller-hsw.html
Our new window switch will work with your setup. The tach wire would be a way to get a good signal
https://ls1tech.com/forums/showthread.php?t=969326
thanks alot for the help mike i do have a question do i have to run everything that comes with the micro edge such as the tps activation or the duels stage control, all the difrent delays you offer. i basiclly want the window switch with a first gear lock out and the air/fuel lean shut down.
Robert
