can somebody help me find rear sway bar bushings??
Old 08-30-2008, 11:15 PM
ae13291's Avatar
Default can somebody help me find rear sway bar bushings??
i have a 24mm rear swaybar and no where online can i find grease able rear poly bushings and endlinks. i have been searching and still nothing! im thinking about calling prothane or energy on tuesday to see if they have the part. so far this is the closest i found to it but its not greasable
http://store.summitracing.com/partde...rt=ENS-3-5147R
Old 08-31-2008, 10:57 AM
ae13291's Avatar
anybody??
Old 08-31-2008, 11:39 AM
Fast_94_Z's Avatar
just put non greasable ones or contact bmr directly to see what they can do for you.
Old 08-31-2008, 12:09 PM
Moderator
jimmyblue's Avatar
You grease them by dropping the keeper straps, separate
the bushing and give it the stinky pinkie. If you're looking
for zerks, I think you're out of luck (that thin sheet metal,
how are you going to mount a zerk anyway?).
Old 08-31-2008, 12:26 PM
Moderator
davered00ss's Avatar
Only the front's have the zerk fittings on them. As for where to get them, AutoZone should have them in stock.
Stock rear bushing is 19mm, right?
Front's have the option of 24mm(z28) or 32mm (on the SS) stock. Aftermarket is what ever.
Old 08-31-2008, 12:38 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Walmart carries them.
Old 08-31-2008, 01:09 PM
vjo90rs8's Avatar
Stock FRONT is 30mm on a Z28, 32mm on a SS
Stock REAR is 19mm but you can easily get a 21, 23, or 24mm bar from a thirdgen camaro or aftermarket.
http://www.top-downsolutions.com/pro...2b0dcf71c2ea28
Not sure if I can post the link, it is a thirdgen parts supplier so i think it is okay?
Old 08-31-2008, 02:49 PM
leadfoot4's Avatar
I agree, but I would think that if you were to drill a correctly sized hole for the zerk, all the way through the metal and poly, A)the zerk would go through the metal and also grab into the poly; and B)the grease would lube the bushing.
Old 08-31-2008, 10:45 PM
ae13291's Avatar
yea i have a 36mm zerk fitted front sway and i just pulled a 24mm sway from a 3rd gen trans am. i see energy carrying zerk fitted bushings for 23 mm and 21 but i dont know why they dont have it for a 24mm bar on the rear?
Old 09-01-2008, 06:15 PM
ae13291's Avatar
bumpity any more info?
Old 09-15-2008, 12:17 AM
djsanchez2's Avatar
http://www.hawksthirdgenparts.com/ca...ushingset.aspx
The drop down box has a 24mm option
Quick Reply: can somebody help me find rear sway bar bushings??
