Rotors warped?
Old 09-01-2008, 06:54 AM
NJgunslinger's Avatar
Default Rotors warped?
Hey if I brake at higher speeds, say over 60mph and feel the steering wheel vibrate, is that because the rotors are warped?
Old 09-01-2008, 11:56 AM
9000th01ss's Avatar
Usually. My OE rotors warped 5 times when the car was under warranty.
Old 09-01-2008, 02:27 PM
AFASTYZFR1's Avatar
sounds warped to me.....has the car been aligned recently?
Old 09-01-2008, 08:12 PM
LS1 Freak's Avatar
Thats rotors, I had the same problem, went and bought new ones( drilled and slotted) and after a year same ****, soon I'm going with Brembo blanks from WS6 store, hope this helps, BTW its not even worth turning them
Old 09-02-2008, 10:19 AM
thanks, i ordered the Brembo blanks
Old 09-02-2008, 10:35 AM
5301113's Avatar
Are the front tires balanced? I know my steering wheel vibrated when my tires were unbalanced after i got a flat fixed
Old 09-02-2008, 11:05 AM
dragonrage's Avatar
Probably deposits left on the rotors by the pads, not actual warping. Rotors can warp, but it's usually the pads.
Get yourself some good pads to go with those rotors to make sure you don't f* 'em up.
Old 09-02-2008, 11:27 AM
Major_Lee_Slow's Avatar
This should go without saying, but make sure when you tighten the wheel lug nuts that they are properly torqued to 100 ft*lbs in two increments in a start pattern. Improper wheel torque is usually the number one reason why rotors warp.
Old 09-02-2008, 11:37 AM
Bad Blue WS6's Avatar
way off topic,,, but ,,, NJ Gunslinger,,is that a BC Rich reference by chance?
Old 09-02-2008, 03:04 PM
No, not sure what or who BC rich is.
Old 09-08-2008, 11:54 AM
BC Rich is a guitar,,and they used to make a model called the NJ Gunslinger,,a very expensive USA made one,,,they are bad *** in terms of guitars,,,,in my opinion, their best. waz just curious as your name on here is such. thanx
Old 09-10-2008, 08:49 AM
ynkssws6's Avatar
Beat me to it. Well said.
