3-point SFC's or standard SFC's
Old 09-03-2008, 02:08 AM
Chubbz155's Avatar
Default 3-point SFC's or standard SFC's
I am wondering what style SFC's to get? The 3-points or the standards. If you guys can give me some info (pro's and cons) that would be great.!! Thanks!
Old 09-03-2008, 08:20 AM
LS1Tech Sponsor
Indukted1's Avatar
Just get regular SFC's!
Old 09-03-2008, 08:33 AM
teke184's Avatar
any sfc are a benefit to the car
2 point are generally lighter
as far as i'm concerned the 3points are a waste on all but the most extreme cars. that 3rd connection point is the tunnel brace mount...which is relatively thin metal to begin with. the only way i can see that being any stronger is if you install an aftermarket tunnel brace along with the SFC.
i installed BMR boxed sfc, which stiffened up the car significantly. and i lost almost no ground clearance.
Old 09-03-2008, 09:48 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
We offer a weld in 2 point in either a boxed or tubular version. If you have any questions please give us a call. We are in the office till 6pm est mon-fri.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 09-03-2008, 03:02 PM
tpunk's Avatar
Get the weld in if you really want SFC's. I found that I didn't need them though after I put on my koni's. The only reason I can think of for really "needing" 3pt's is if you have a tunnel mounted torque arm. The reason I say this is the floor pan isn't very well reinforced here so it would help as a strengthener. I would stay away from a tunnel mounted arm for a street car though as they can contribute to brake induced wheel hop (unless you get the Unbalanced Engineering decoupling arm for the price of your right arm). The Boxed 2pt arms are very nice for a jacking rail though and are almost woth it for that alone and BMR's SFC's are not a bad option. Probably more info than you needed... sorry.
Old 09-03-2008, 06:02 PM
Fast_94_Z's Avatar
these guys are right. if you have a tunnel brace mounted torque arm and aftermarket tunnel brace then it 3 points work more to your advantage being in a sense that the weight will distribue more evently. if you dont plan on getting a tunnel brace mounted torque arm then your better off with 2 points. if your interested in some 3 points i have some for sale they are brand new from umi.
Old 09-04-2008, 11:35 AM
LS1TECH Sponsor
Sam Strano's Avatar
2 pts. are cheaper to buy and ship
3 pts. are stronger
Simply put, if you feel the car needs to be improved in terms of chassis stiffness how can you not opt for 3 pts.? The only reason to run 2 pts. is cost. They cost less because there is not as much to them.
I'm not saying that 2 pts. are bad. Hell, I think in a number of cases SFC's are not required or needed. I'm simply saying you need to weigh what you want to improve and what it's worth to you.
But if you run a tunnel mount TA, I feel 3 pts. are a must do.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 09-04-2008, 12:23 PM
Chubbz155's Avatar
Thanks for the all the input fellas!!!
Old 09-04-2008, 12:54 PM
UMI Performance's Avatar
Hello,
If you are running any type of shorter tunnel mounted torque arm I recommend the 3-Point SFC's since they bolt under the torque arm mounts to prevent stress to the floor of the vehicle. Other than that the 2-Point set-ups will be just fine.
We offer a large selection of SFC's seen here- http://www.umiperformance.com/produc...ategory_id=129
If you have any questions please ask. Thank you!
Ryan
