Throwing Codes!!
Throwing Codes!!
Car threw a P0332 code...scanner said the follwing:
Knock Sensor 2
Circuit Low Input
(Bank 2)
I basically just have full exhaust and intake with some suspension stuff on my 2000 Z28 M6...just want to know what I have to do to get this taken care of. I need a tune don't i?
Knock Sensor 2
Circuit Low Input
(Bank 2)
Knock Sensor 2
Circuit Low Input
(Bank 2)
Knock Sensor 2
Circuit Low Input
(Bank 2)
http://www.ls1howto.com/index.php?article=5
Once it's off, simply remove and replace the knock sensors. Use two screw drivers or a pair of pliers to gently squeeze on the wide ends of the gray connectors on the knock sensors. IIRC it should be a 7/8 socket to unscrew them. Check the wiring thoroughly.
Here's a picture:
Good luck with it.
