VSS Adapter
Old 09-10-2008, 05:04 PM
Eddie 70's Avatar
Default VSS Adapter
On my conversion I am running a Keisler TKO 5 speed transmission. It does not have a VSS output. I want a VSS so I can tune easier. Do they make an VSS adapter that will go into the speedo output on the transmission and let the speedo cable connect to it and give me a place to connect for VSS? I am keeping my mechanical speedo and only using the VSS output for tuning.
I hope I have made this clear enough to understand. Any help would be greatly appreciated.
Old 09-10-2008, 05:39 PM
cacmanjr's Avatar
Default Vss
I believe that autometer makes one to power their electronic speedometers. It has the cable connection for the old style cruise control units.
Old 09-10-2008, 06:08 PM
Eddie 70's Avatar
#54MG. Eight pulse signal generator for your electronic speedometer head. This goes behind your dash and plugs to the head and drives off of your old speedometer cable. Doesn't include the cables. Can be installed inline for both mechanical speedometer and pulse generator. Cost $63.00
I found this and it looks like what I think the part should look like. I can connect the adapter to the trans, then the cable to the adapter and get my pulse from the pigtail. Anyone have any experience with this?
Old 09-10-2008, 06:54 PM
Pop N Wood's Avatar
My Keisler TKO has both mechanical and VSS outputs. When did you buy yours?
Old 09-10-2008, 07:04 PM
Eddie 70's Avatar
It has been installed since 10/2003. I had the trans in my garage for about 6 months before I got around to installing it. On the back of the trans, on the drivers side, there is a black plug that has two wires coming out of it but that is only a neutral switch. If I am not mistaken the VSS is on the passengers side of the trans.
Old 09-10-2008, 08:54 PM
LS1MCSS's Avatar
That's a two wire sender so it will put out the correct type of signal. What program are you using to tune the pcm and what pulse output is the vss?
Old 09-11-2008, 05:35 AM
Eddie 70's Avatar
It says it is an 8 pulse generator. Does not say whether it is a sine wave or square wave output though. I am using HP Tuners to do the tuning.
Old 09-11-2008, 07:18 AM
355ss's Avatar
I am using the Dakota Digital "SEN-01-4160" on my t-56 that was converted to a cable speedo drive. I have it installed inline and the cable passes through to drive the speedo. I am also using HP Tuners and it works great.
Old 09-11-2008, 02:44 PM
Eddie 70's Avatar
Nice find. This Dakota Digital is even closer to what I need for my Keisler trans,
SEN-01-2 - 8K pulse generator with adaptor cable for Ford transmissions with cable drive speed output.
Old 09-11-2008, 03:46 PM
garys 68's Avatar
What are the prices on those units?
Do they allow for using an electric speedometer?
I'm putting an LS in my 68 vette and was going to run a mechanical tach but no VSS for the computer.
I've heard of stalling problems without VSS, so now I'm thinking I could use the adapter and run all electronic guages.
Old 09-11-2008, 04:38 PM
Eddie 70's Avatar
Gary, they put no prices on their webpage but I would suspect that Summit or Jegs or someone like that might sell those adapters. If you follow this link you should be able to look at the adapters and see one that you might be able to use. I still am not convinced about the adapter working with the tunnel clearance. I might just have to buy one and put it to work and see. Seems like they were around $40-$50 which I am okay with if it gets me what I want and need for the swap.
Here is a link to DD's webpage with pricing. Easy on the pocket if it works.
Clickity click
Old 09-11-2008, 06:37 PM
LS1MCSS's Avatar
From Dakota Digital, you need p/n SEN-01-4160 .
Old 09-12-2008, 12:59 PM
garys 68's Avatar
One other note. I was a post where a Tremec had an adapter on it with a pulse output as outside the range of the LS computer. Dont know if it's relevent, but worth checking.
Old 10-01-2008, 09:32 PM
cacmanjr's Avatar
Default dakota digital SEN-01-4160
Does the Dakota Digital SEN-01-4160 put out the proper signal for the LS1 VSS input to the PCM?
Old 10-02-2008, 11:07 AM
LS1MCSS's Avatar
I have never heard of that. With HP Tuners, you can go all the way to 0 pulse in the settings. The last time I checked, EFI Live only went down to 10 pulse. Maybe that is what they were talking about.
Old 05-30-2009, 08:55 PM
Eddie 70's Avatar
Just wanted to bump this up again. My tremec has a speedo cable that is the ford style (I assume) at the trans end and then connects at the GM Speedometer.
I do have HP Tuners but I paid someone, Chuck CoW, to tune my car last weekend. He did an excellent job with it. There were some tables that cannot be tuned if there is no VSS.
So with the decsription above of the speedo cable, does the SEN-01-1 by Dakota Digital seem like the correct one?
Old 05-30-2009, 09:01 PM
LS1MCSS's Avatar
I'm not sure if it will connect to a ford cable or not.
Quick Reply: VSS Adapter
