how much hp/tq is made with full bolt ons
in a lt1 car. minus the stall,gear which wont really effect hp. with or w/o roller rockers. but on a stock internal lt1 how much power is noted.
with or w/o injectors tune is a must i agree to get the most power.
it seems like its all over the place, i would hope to get at least 300rwhp once i get my LT's on and a retune, but i've seen this vid long time ago and wondered if its plausible they show no dyno graph.
1996 Chevrolet Camaro Z28 LT1 NJFBOA Dyno Day Vide
300 is very doable.
I put down 279 with a catback, highflow cats and a K&N filter when I bough it a few years back.
Didn't even have a mail-order tune on it at the time.
http://i38.photobucket.com/albums/e1...Dyno040106.jpg
Add LTs, a tune and you should have no issue hitting 300, even with an auto.
1.6:1 rockers and an EWP don't hurt either.
Now, if you're looking for speed ....
Drop weight wherever you can, all the stuff you don't need in the car.
(There's a whole list over in the drag racing section)
You'll need sticky tires and good suspension as well.
In the example above Shon didn't hit 11.80 with a full-weight car.
320rwhp will generally not get an Fbody into the 11s.
(At least not without dumping 700-1000lbs and a few traction/suspension upgrades)
302/321, M6 car, 1.6 promag RR, forgot which ones but comp cam springs, K&N CAI, bbk shorties, 3" catback, granatelli MAF, MSD 6a, trickflow ceramic coated elbow, msd opti and coil. Best has been a 13.5@104, with a horrible 2.2 60', only weight out of the car was rear seats/belts and spare and jack. No tune.
I did the numbers in the sig.
I have every bolt on except a ewp.
Mac mids
Hooker CB
crane gold 1.6rr
crank pulley
52mm tb
ls1 ds
1le elbow
airfoil
e cutout
no cat
and my heads and intake are gasket matched(1.5hrs of light work)
And it was on 18 inch zo6 rims with a 3.73 gear in the 10 bolt. I am throwing on a LS1 lid, mallory 685, and csi ewp, 30 lb injectors. Shooting for 340rwhp.
If you would like the graph post your email.
Mac mids
Hooker CB
crane gold 1.6rr
crank pulley
52mm tb
ls1 ds
1le elbow
airfoil
e cutout
no cat
My best time was run in my sig. with full bolt-ons (stock rockers) & 4.11s at 2500ft. DA on a 2.00 60ft., i'm guessing my rwhp is between 280-300, this is at full weight with spare & jack.
