how much hp/tq is made with full bolt ons
Old 09-15-2008 | 12:50 AM
robsquikz28's Avatar
Default how much hp/tq is made with full bolt ons
in a lt1 car. minus the stall,gear which wont really effect hp. with or w/o roller rockers. but on a stock internal lt1 how much power is noted.
with or w/o injectors tune is a must i agree to get the most power.
Old 09-15-2008 | 07:48 AM
1badzee's Avatar
A stall/converter does in fact affect hp #'s on the dyno
Old 09-15-2008 | 07:57 AM
BIG_T's Avatar
each car is different i have seen full bolt on and gear cars make high 290's and some make it in the 315-320 range with rr's
Old 09-15-2008 | 11:32 AM
CamaroRacing12's Avatar
highest i have seen on here or anywhere is in the 320rwhp range
too me track times r most important...
bolt on only record is 11.80 set by shon herron
john p. (1slowformula) has gone 11.86
and a bunch of guys have gone low to mid 12's
Old 09-15-2008 | 12:08 PM
AChotrod's Avatar
I also say 310-320ish is about the max
Old 09-15-2008 | 12:17 PM
ScreaminRedZ's Avatar
registered user
Through an auto I'd think it'll be somewhere around 300. Maybe 310 at the most.
Old 09-15-2008 | 12:23 PM
tspence45's Avatar
That'd be my guess. But, I'd say it'd be doubtfull to hit 300's with a stall and stock RR's.
Old 09-15-2008 | 12:44 PM
95hitam6's Avatar
it seems like its all over the place, i would hope to get at least 300rwhp once i get my LT's on and a retune, but i've seen this vid long time ago and wondered if its plausible they show no dyno graph.
1996 Chevrolet Camaro Z28 LT1 NJFBOA Dyno Day Vide
Old 09-15-2008 | 12:51 PM
James Montigny's Avatar
300 is very doable.
I put down 279 with a catback, highflow cats and a K&N filter when I bough it a few years back.
Didn't even have a mail-order tune on it at the time.
http://i38.photobucket.com/albums/e1...Dyno040106.jpg
Add LTs, a tune and you should have no issue hitting 300, even with an auto.
1.6:1 rockers and an EWP don't hurt either.
Now, if you're looking for speed ....
Drop weight wherever you can, all the stuff you don't need in the car.
(There's a whole list over in the drag racing section)
You'll need sticky tires and good suspension as well.
In the example above Shon didn't hit 11.80 with a full-weight car.
320rwhp will generally not get an Fbody into the 11s.
(At least not without dumping 700-1000lbs and a few traction/suspension upgrades)
Old 09-15-2008 | 12:54 PM
camar0corey's Avatar
302/321, M6 car, 1.6 promag RR, forgot which ones but comp cam springs, K&N CAI, bbk shorties, 3" catback, granatelli MAF, MSD 6a, trickflow ceramic coated elbow, msd opti and coil. Best has been a 13.5@104, with a horrible 2.2 60', only weight out of the car was rear seats/belts and spare and jack. No tune.
Old 09-15-2008 | 01:09 PM
so if a car runs 13.47 at 104 does that mean its a 300 hp car at 3450lbs with 1.98 60ft.
Old 09-15-2008 | 01:14 PM
kinglt-1's Avatar
With flowmaster catback, K&N cai, Hypertech chip. I trapped 105 on a 95 degree summer day.
Old 09-15-2008 | 01:17 PM
kinglt-1's Avatar
I would say 280whp 310wtq. 300whp shoul get around 106 trap
Old 09-15-2008 | 01:26 PM
because all i had were lt's,ory,full exhaust and cai everything else bone stock 3.23 gear and a4
Old 09-15-2008 | 02:11 PM
AChotrod's Avatar
yes I would also say 300 for an auto is a good number
Old 09-15-2008 | 02:14 PM
That's about right. The LTs make a HUGE difference.
Old 09-15-2008 | 02:21 PM
slomarao's Avatar
I did the numbers in the sig.
I have every bolt on except a ewp.
Mac mids
Hooker CB
crane gold 1.6rr
crank pulley
52mm tb
ls1 ds
1le elbow
airfoil
e cutout
no cat
and my heads and intake are gasket matched(1.5hrs of light work)
And it was on 18 inch zo6 rims with a 3.73 gear in the 10 bolt. I am throwing on a LS1 lid, mallory 685, and csi ewp, 30 lb injectors. Shooting for 340rwhp.
If you would like the graph post your email.
Old 09-15-2008 | 02:40 PM
LM97Z's Avatar
My best time was run in my sig. with full bolt-ons (stock rockers) & 4.11s at 2500ft. DA on a 2.00 60ft., i'm guessing my rwhp is between 280-300, this is at full weight with spare & jack.
Old 09-15-2008 | 08:00 PM
lt1-xjs's Avatar
Switching from 1.6 s/a Promag's to 1.7 Scorpions gained me 10 rwhp.
It put me at 309 rwhp.
Old 09-16-2008 | 11:09 AM
now by putting in a 3.73 gear how much of a power gain can there be
