A couple of questions... LS1 240sx with 4L60E
Hey everyone, Im about to finish my LS1 240sx build, and Im missing on a few points...
What did u use to cool down ur tranny? cause my radiator has a cooling place for the tranny (BMW Radiator) but I've heard bad things about it, and an external one should be done, but my problem is that I can't find one in my country I should get one from abroad, should I wait, or can I use the one on the radiator for a while? (I have a 4l60e on my S13)
About the oxygen sensors, I have no cats and nothing on my car, what should I do? what sensors did u use? Simulators? and from where did u buy them? any DIY thread on these? (is anyone running without them?)
ok lets forget about tunning them out of the ECU because noone does it in my country... so this is one option gone... my other options is to actually do them... so how will I do them... 2 in front (02 sensors, any part number?) and 2 02 sims in the back?! anything recomended? thanks
how are you going to get it to run without removing VATS from the ecu?
and technically you dont need front or rear o2 sensors. i dont run either. car runs great. 12.4:1 AFR all the way to redline.
Im in the middle east, from a country called Lebanon, city: beirut...
And the problems I found which Im surprised my car actually worked without them are actually no CAM SENSOR plugged, and No MAP SENSOR plugged!!!!! or it was actually broken..
