put lt1 intake on 406 possible
Old 09-22-2008, 10:06 PM
2badz28's's Avatar
Default put lt1 intake on 406 possible
I have a built 406 fully forged I have heard of golen fitting sbc dart heads on lt1 with stock intake I was wondering the costs of doing this
Old 09-22-2008, 10:10 PM
NSTIGATR's Avatar
lt1 will fit standard sbc dart heads. what kind of stock intake you talking about? stock lt1? standard and vortec style intakes bolt completely different, plus the stock lt1 intake will prolly be pretty restrictive with that 406 and the dart heads if you could make it work. im not saying it cant be done...but monetarily wise...it woudnt be worth it. put on a single plane and a good holley.
Old 09-22-2008, 10:21 PM
2badz28's's Avatar
I have it in a monte carlo ss now with a tunnel ram and twin 600's I just wanted to cheaply put it in my 94 z28. F-body freak what can I say
Old 09-23-2008, 04:37 PM
NSTIGATR's Avatar
well you can put it on an lt-1 just not run lt-1 intake.... many carbed guys runnin lt-1s
Old 09-24-2008, 02:13 PM
2badz28's's Avatar
The question is can I have my heads machined to put the stock lt1 intake on standard sbc heads I have heard golen engine services does this
Old 09-24-2008, 02:34 PM
The Engineer's Avatar
Give Chad Golen a call and see what he says (123-885-3830). Also, Chad is a great guy to talk with, he'll get you lined-out.
WD
Old 09-24-2008, 03:00 PM
ulakovic22's Avatar
I'm just talking out loud here, but LT intakes are dry so you need to think about that. Drilling the SBC heads for LT bolt pattern shouldn't be difficult for a machine shop. Why are you wanting to put an LT manifold on a SBC anyway? You won't be able to run a carb and to run fuel injection on your 94 F-body the computer will need a cam and crank sensor that the opti normally provided. With a SBC you won't have provisions for the opti.
Old 09-24-2008, 03:05 PM
fergymoto's Avatar
Why not just get a nice single plane and stick with the carb? It would be a lot less trouble for you and probably make more power.Not to mention easier to tune.
Old 09-24-2008, 08:58 PM
2badz28's's Avatar
I already have the lt1 intake. The crank sensor didn't come out till 96 and is it possible to run a cam sensor if not I guess the 406 will go up for sale I appreciate all the info
Old 09-24-2008, 10:26 PM
ulakovic22's Avatar
The crank sensor on the OBD2 engines is only for misfire detection, has nothing to do with timing. My understanding is to run multi port fuel injection you need both crank and cam sensors and I believe that the opti provides both these signals to the computer as High and Low res pulse.
Old 09-25-2008, 07:24 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Just buy a single plane and get injector bungs put in it. I'm pretty sure edelbrock already sells some set up for EFI. Sell your LT1 intake and it will cost you about the same as having the LT1 intake converted. Then you can run a normal distributor instead of the opti.
Old 09-25-2008, 08:26 PM
ulakovic22's Avatar
A normal distributor still won't provide the computer the correct opti signals to run MPFI, you will still need a 2X cam signal on your cam gear and timing cover.
Old 09-25-2008, 08:36 PM
OWN3D BY MY PROF!
I didn't mention it, but you can still run the opti for optical cam sensory. Plenty of people have done it before. You could also go use a crank trigger.
Old 09-25-2008, 11:12 PM
ulakovic22's Avatar
Only way to run a 406 in a 94 F-body is to go carb'd and toss on a distributor or get an aftermarket computer so he doesn't have to use the opti. He wants to use the LT1 intake, meaning he wants to run fuel injection and use the LT1 computer. To do that he needs to figure out a way to replicate the cam and crank signals and get the intake bolt pattern converted.
I'm running a MSD distributor converted for a cam signal and a crank trigger, but this is on a BBC, not a SBC. Point is it can be done, but not cheaply. Cheaply would be to toss on a carb and dist. and be done with it since he already has the whole engine ready to go.
Quick Reply: put lt1 intake on 406 possible
