upgrade ya
gm
is the gm performance part the same as the ac delco?? plus wanted a vented unit gm performance opti+msd cap and rotor= more than the price of the MSD opti? decisions decisions. made the mistake of calling the chevy dealership 650 for a new opti wow i call rape.
if your running 450+ then odds are your running your motor well over 5500 rpms at the track...was stating that the acdelco isnt going to hold up and s dynspark is the better of the two if he is going to spend 500 on an opti....if you read his post he asked if it would add hp and i clearly put into words he would understand because obviously he is a newb...these guys work slowly up the pole and we cannot confuse them....i know what im talking about im not dumb....just put things in words he could understand thats all...
newb on duty
not an expert at all and no claims to be. thats why i asked. merely wanted an opinion on which direction to go. thanks to those who dont use these threads as a pissing contest.
If your car is a 95-97 here it is for $310
http://store.summitracing.com/partde...5&autoview=sku
If it's a 92-94 $395
mods
1995 Camaro Z-28 .......no problem somethings are read wrong here are a few mods. not my everyday car drive mainly to the track and back home. But must admit nearly blind when it somes to electrical problems sorry. start at the mouth, 355/LT1 breaths through moroso Cai, granatellli Maf sensor, trickflow elbow, stock TB with foil,port and polished heads, stock 95 cam, march under drive pulleys, Ac delco plat plugs, MSD 8.5wires, Pacesetter Longtubes, no cats, 3 inch true duals X out 2 dynomax bullets before axel. no tune yet........
you should be fine with a delco....those prices seem odd...the vented opits are usually more...go to ebay and look up partsladi....she sells a good opti...alot of ppl are going with her and not ahving probs...its the same as the acdelco just a different brand...its ok to get though...now all_ignition some guys have had probs with, but i bought from them and havent had a problem yet...we will see...look up both of them...dont buy cheap one from all_ignitioin buy the actaul all_ignition one..basically an acdelco opti with a different pickup..acdelco uses a mitsubishi pick up and all_ignition uses theirs which is an exact replica of mitsubishi
And as far as saying (not you Fergy) you should get an aftermarket Opti if you're spinning over 5500 is retarded. Stock rev limiter is set @ 5851 (.43 is you want to get **** lol), and many people spin around 6300 on a Delco Opti.
