What 1.6 rockers?
What 1.6 rockers?
Hey iam looking at putting 1.6 rockers on my right now stock internal lt1. These really help on a stock internal motor? what could i expect from them over stock?
What brand would you suggest?
also i heard i need NSA rockers, that true?
would i need new pushrods or anything else besides the rockers?
thanks a bunch!
thanks a bunch!
Running 1.6's on your otherwise stock car basically is like getting more lift from the cam. You might see 10rwhp. I'd say you'll see a tenth or so. I run magnums in my 383. If I was you and you were doing the rockers, you may as well go ahead and replace anything you can 'easily" while your in there. Pushrods cant hurt, studs wouldnt be bad.
Thanks so much for all the replies about the rockers, but can anyone answer my question about the pushrods? do i need new ones? can i use stock? if not what length? need hardend?
If you go with nsa rockers you will need guide plates and hardened pushrods for the guide plates. I dont see any problem with running stock length push rods if you are not changing out your cam.
thanks a bunch!
thanks a bunch!
