Mac Mids problem
Mac Mids problem
I installed my mac mids, but the header hits on the streeing shaft.The number 3 exhaust port pipe just barely.What can I do about this cuz it makes it a hard to steer.
BTW i hate headers!
haha i win!
I don't know how our steering setup is, but assuming there's a ujoint inside, you could always remove everything from the firewall and oblong the holes out just a tad. You'll obviously want to make sure you tighten down your bolts with an impact after, so it doesn't slide any. That'll keep you from having to grind down your steering shaft or denting your new headers.
You could also just need new engine mounts. Even if that doesn't fit it, it probably wouldn't be a bad thing to do anyways
Relocating? No. But doing exactly what this guy said, yes. Only I suggested oblonging the holes a bit so it would slide more, if simply loosening them wouldn't cut it.
Yep, because they only make high torque impacts. No such thing as a 1/4" impact. So to you as well The more you try to make me look stupid, the worse you come across in my eyes. And your trolling is getting kind of old too.
I'm not trying to give expert advice. I'm trying to give advice that works. If I implied that I knew everything, I'd just go out and say "Since I know everything, you should do this". And yet, 2 posts later, someone offers almost the exact same damn thing I did, but there was no lame *** retort by you for his post. Which leads me back to you turning into a troll. So I'm thinking you should just go back to being quite.
