The beast won't crank!!!
Old 09-26-2008, 02:40 PM
97SSCamaroGuy's Avatar
Default The beast won't crank!!!
Dynaspark went in, new plugs and wires, the usual crap...car ran before but not great, now it won't fire. It's getting gas and the coil is ok, and all my wires and what not are ok, just seems like my timing is WAY off. How can I fix this? Is there any chance that I put the opti in wrong?
Old 09-26-2008, 02:41 PM
Here's a video to help you out...
http://www.youtube.com/watch?v=XrUZduZZFMo
Old 09-26-2008, 04:06 PM
slingshot928's Avatar
After taking my opti off a couple of times, i learned to start the car with out the water pump on and just the bare necessities need to start, only to make sure it was good before the water pump and fans went in...
Old 09-26-2008, 04:16 PM
i wish i would have paid closer attention to what i was doing this morning...16 hours solid of working on the car and all i could think of was getting it back on the road....
Old 09-26-2008, 04:55 PM
fergymoto's Avatar
Did you figure it out then or no?
Old 09-26-2008, 07:20 PM
I'm going to pull the opti and retry...I'm pretty sure I don't have it in right...cross your fingers!
Old 09-26-2008, 10:14 PM
SoxXpupPeT's Avatar
my dad had a problem when he installed his opti. they say you cant F up installing it but his was about 70 degrees out of wack. it would sound like it would start but it wouldnt. id check that if you redid your opti
Old 09-27-2008, 02:22 AM
I remounted the opti and everything is AWESOME!!! Only problem is that it's kinda misfiring or falling alittle at really high RPMs. Should I replace the coil? Or is this something else?
Old 09-27-2008, 09:31 AM
SoxXpupPeT's Avatar
glad to hear its fixed! that was my dads exact problem. it was driving us both mad for 2 days until we remounted it. fired Right upa nd ran great. if i were you id check my wire if there arching and plugs. something might not be 100% with that and thats a cheaper and faster fix then a coil. but if your coil is stock then replace it with MSD Blaster and call it a day
Old 09-27-2008, 01:40 PM
Note to self and everyone else that might not know...DO NOT BUY ACCEL PRODUCTS!! I put my stock coil back on and the car runs just fine.
Old 09-27-2008, 05:18 PM
jarretthise's Avatar
lol man that is a known fact here....accell= junk...opti, coil, wires, ignition box, its all junk...lol....glad to here ya got her running though
Old 09-27-2008, 06:02 PM
Car is down again...cold start it runs perfect then when it gets up to temp it starts back firing at full throttle and stutters all to hell when i come to a stop...what now?
Old 09-27-2008, 07:22 PM
lifeisgood's Avatar
dude im sry to hear that your having the same problem i did with my car. my 96 m6 did the same thing. and i couldnt figure it out. no one i had ever talk to could either. i ended up trading the car in on a c5 and the next guy that bought it never figured it out. i did away with the opti all together with the delteq opti and still no fix.
Old 09-27-2008, 11:15 PM
SoxXpupPeT's Avatar
bah that sucks man. but my dad doesnt have a problem with his accel opti. nor i with my accel coil. could be something vacuum related now. i think my ICV is messed up abit because it doesnt back fire but it sputters abit. especially when going into first from a standstill
Old 09-28-2008, 12:29 AM
Fixxer99TA's Avatar
I would take that coil/ICM to your local autozone or anything local and have them test em... Start with the cheap stuff first. Since things arent getting screwy until the car is warmed up now, thats where I would start.
Since your opti is a new Dynaspark, I would not think you got a bad one.
Old 09-28-2008, 04:10 PM
I took my coil and icm to autozone and they said they cant test them??? I'm going to put some more washers behind the mounting plates on the coil and see if I can get that heat off of them and maybe the car will run alittle better. The backfiring also made my crank position sensor go bad...I'm replacing that too.
