Recommend me a lumpy idle turbo cam
Old 09-29-2008, 06:22 PM
shawn_c992001's Avatar
Default Recommend me a lumpy idle turbo cam
Ok guys, just as the title says. I'm looking for a turbo cam with a nice lumpy idle, what would be the best.
Old 09-29-2008, 07:01 PM
StingrayCrazy's Avatar
In my opinion...
Not recommended with your current setup due to high turbine back pressure. STS systems like stock or camshafts with little overlap...
If you changed your combo and turbo to achieve, or get close to a 1:1 boost to back pressure ratio you could run a more conventional N/A camshaft and have some lope...
But keep in mind, For a street car with a true 1:1 pressure ratio you will loose response and quick spool in favor of higher HP numbers. Not necessarily good for street use but great for the strip.
Old 09-29-2008, 07:11 PM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com....html?item=679
We used this cam in this STS Camaro.
http://www.exoticperformanceplus.com...Car.php?car=32
Video: http://s81.photobucket.com/albums/j2...MOV00004-1.flv Bob
Old 09-29-2008, 08:40 PM
Bob, about how much HP & torque does the cam alone with a turbo yield? I will need dual valve springs right?
Old 09-29-2008, 09:02 PM
Pat-Man's Avatar
Dual valve springs are a must with a .600 lift or higher...definitely with an FI application.
Old 09-29-2008, 09:11 PM
Josh@PremierAutosports's Avatar
I'm running a ls1 speed 235/235 in my 404 and it hits harder than I thought it would
Old 09-30-2008, 05:02 AM
EPP
EPP's Avatar
That is a tough question to answer, as there are a lot of variables involved. One guy recently added our cam to his N/A car, as he wants to add forced induction next year, and he picked up 41 rwhp.
The Patriot Gold valvesprings are normally what we use with our cam. Bob
Old 09-30-2008, 08:53 AM
OUTLAWZ RACING's Avatar
Scotts car had me sold on the epp cam. I love it lumpy as hell and makes power numbers in the sig.
Old 09-30-2008, 09:11 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
240/244/112 Vengeance Cam:
View Video on FQuick
Old 09-30-2008, 09:12 AM
LS1Tech Co-Founder
Speed Inc. 236/236 cam:
Old 09-30-2008, 09:41 AM
Pat-Man's Avatar
WOW!!! That sounds mean as hell. That's not a FI cam though, is it?
Old 09-30-2008, 01:06 PM
7845's Avatar
230/236 115 lsa
http://videos.streetfire.net/video/Q...8mm_182920.htm
Old 09-30-2008, 04:41 PM
LS1Tech Co-Founder
NA cam but there are some 240/244 FI cams out there.
Quick Reply: Recommend me a lumpy idle turbo cam
