Subwoofer power lead thru firewall
I thought I saw a suggestion on where to run my 10 gage power wire from the sub to the battery in here. I have searched but cannot find it. Anyone have a suggestion?
Thanks in advance,
Thanks in advance,
Ive got an 07 GXP and I think I did mine in the best possible spot. Peel back the carpet a bit on your passengers side floorboard right below the glovebox and theres a nice big black grommet towards the floor you can drill/cut through.
Open your hood and with a 10mm socket take out your computer (passenger side corner) Behind it there is a rubber grommet...run the wire there and down under your carpet. I can do this wire run in less than 5 min so YOU spend 30 min your first time and take your time to do it right.
BTW 4 guage is fine unless you are running over 2000 watts rms....10 gauge is tooooo small unless you are running a tiny amp (under 200 watts)
dont do it this way...please...i have had to work on plenty of **** because people do **** this way..the WRONG way.
Please do show us all mighty 427Cya
Cool... I was a bit concerned about trying to run it through the pass side grommet because it would be less than an inch from the exhaust manifold.
Thanks for digging this up. My speakers and amp came today. I got the 4 gauge cable in a kit. Yeah, I'm guilty of running my LED wires through the door grommet, but hey, it works good for me. Hopefully will start tackling the project next week.
