Subwoofer power lead thru firewall
Thanks in advance,
Open your hood and with a 10mm socket take out your computer (passenger side corner) Behind it there is a rubber grommet...run the wire there and down under your carpet. I can do this wire run in less than 5 min so YOU spend 30 min your first time and take your time to do it right.
BTW 4 guage is fine unless you are running over 2000 watts rms....10 gauge is tooooo small unless you are running a tiny amp (under 200 watts)
Please do show us all mighty 427Cya
