Sponsored by: DashLynx
!WIRE mod finished (pics)
Old 09-10-2003, 11:48 PM
99TranTrany's Avatar
Default !WIRE mod finished (pics)
I finally got around to doing the !wire mod today. I gotta say this mod is a PITA but free and worth it! The hardest part was cutting the hole and trying to get it the right shape. The wires just were long enough not to have to do any cutting. Good thing because who knows what I would have screwed up if I had to cut the PCM wires! Makes the engine bay look alot cleaner. I've also taken out the whole AIR system and the EGR valve and bracket. And moved the ground wires.
Before.....
hole...
After.........
P.S. Im watting for the other FRC cover to come in still. hopefully tomorrow.
, justin
Old 09-10-2003, 11:52 PM
Default Re: !WIRE mod finished (pics)
WOOOHOOO! I finally found out how to post pics!!
Thanks do0dfromcali
Old 09-11-2003, 12:36 AM
Ferocity02's Avatar
Hey! Nice job, I would do it but I'm waaaayyy to lazy. Other things have to come first, like the rear end that alsmost fell out a couple weeks ago
Old 09-11-2003, 10:29 AM
UGOT8's Avatar
I found this mod to be really easy. However removing the EGR system is a BITCH!
Old 09-11-2003, 11:37 AM
The EGR removal took like 15 min max, what did you have trouble with? My bigiest problem was cutting the hole. I didnt go buy a one inch whole saw bit like every one said to do insted I used this burrowing bit I had here that I thought would work. Big mistake!! The steal ate the bit up real qiuck and left me drilling holes. So my advice is dont be a cheap a$$ like me and go buy a howe saw bit.
Old 09-11-2003, 01:43 PM
Steve1969LS1's Avatar
looks much neater now
less IS more...
Old 09-11-2003, 03:57 PM
WICKED SS's Avatar
Looks good!
I removed my AIR system also, just gotta find time to do the wire mod.
I am kinda confused on where you cut the other hole? I know you cut the one at the top and route it through the wheel well but where does it go from there?
Old 09-11-2003, 04:46 PM
MIGHTYMOUSE's Avatar
did you say you were able to do this without cutting the plugs off or lengthen the wires? please enlighten!
Old 09-11-2003, 04:47 PM
Turo's Avatar
wow, that looks sweeeet! one more thiing to ad to the "to do" lisst
Old 09-11-2003, 10:52 PM
JaxWS6's Avatar
I believe you only cut one hole. There is a big gap on the other side of the wheel well so you don't have to cut another hole!
Old 09-11-2003, 11:37 PM
do0dfromcali's Avatar
Thanks do0dfromcali
No problem at all. Thanks for throwing me some props.
Old 09-11-2003, 11:50 PM
JaxWS6's Avatar
Love the avatar thing you got there do0dfromcali!!
Old 09-12-2003, 12:14 AM
Yup. The trick is the hole. it need sto be as close to the hood strut bracket as possible. And it needs to be made in more of an oval shape so you can get the plugs through. Just be carefull that you dont cut any of the wires comming out at the top of the plug on the meatal edge of the hole as your working them trough.
And yes there is a hole at the front the wires come out through.
, justin
Old 09-12-2003, 10:04 AM
UGOT8's Avatar
I'm talking about removing my entire EGR system. I had a problem creating block off plates for the exhuast where it hooked into the EGR.. not to mention the rag that got sucked into my intake when making sure there were no leaks. EEK ! but i got it out thank god.
::Austin::
Old 09-12-2003, 11:48 AM
lots of places (including myself) sell blockoff plates for that
Old 09-12-2003, 01:11 PM
Thanks...Nothing better then two hot chicks like that making out.
Old 09-12-2003, 01:44 PM
Vents's Avatar
looks VERY clean. ya got me to thinkin again, since that wheelwell is out anyway...
mad props.
Old 02-12-2010, 12:27 PM
thecobrahunter's Avatar
Has anyone had any issues, after drilling the holes on both sides, with any negative structural effects on the shock towers? You know, like when taking corners hard and stuff? No sense in me doing this if it's gonna weaken the shock towers significantly.
Old 02-12-2010, 12:30 PM
Trans Am Jam's Avatar
look good. one of these days I need to pick up a grommet for mine.
Old 02-12-2010, 12:32 PM
94TRANS's Avatar
this thread is like 7 years old lol
