View Poll Results: At what mileage did you replace/repair your transmission?
0-20,000 Miles
2
18.18%
20-30,000 Miles
0
0%
30-40,000 Miles
2
18.18%
50,000+ Miles
7
63.64%
Voters: 11. You may not vote on this poll
Longevity Of Your Transmissions
Old 04-24-2009, 12:16 PM
Striker's Avatar
Default Longevity Of Your Transmissions
Hey guys,
Im curious to see what the trend is around here when it comes to broken and fixed trannies.
Id like to start a poll to see how long it took(mileage) before your unit failed and had to be replaced/repaired. It seems to me that the typical failure occurs between 30-50,000 miles. *This is going by the light reading i've done here every now and then.
Thanks and please vote!
Old 04-24-2009, 12:27 PM
LS1Tech Sponsor
06MonteSS's Avatar
didn't vote - cuz I haven't had to repair or replace mine yet... and it's still strong as ever, runs like new... haven't had any issues with it...
and I'm just about at 69,000 miles....
and I don't baby it either... I get on it all the time... whenever I have enough room in front of me, I'm on it...
and have left my fair share of dual burn-outs on many a road/driveway too...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 04-24-2009, 12:57 PM
impala06ss's Avatar
Looks like you are only polling cars that have failed already, mine hasn't failed yet either, 50k.
Old 04-24-2009, 01:04 PM
BuffaloSS's Avatar
You need to add "suspect it to fail soon"...cuz that's where my vote would be placed. Every once in a while it will clunk when first accelerating, and the highway shifts are getting super sloppy. It likes to stay in 3rd a lot, and I need to play takeaway with the gas pedal to get OD to engage at times.
Are these symptoms of the Valve Body failing? What's the typical cost to get this fixed/replaced before the whole thing blows?
EDIT: ~46,000mi
Old 04-24-2009, 01:18 PM
beznich's Avatar
Mine is still good - so far . 25K
Old 04-24-2009, 01:28 PM
tokay57's Avatar
mine has 21,000 miles and seems fine, however, mine tends to short shift from 2nd to 3rd at wot. Is that normal?
Old 04-24-2009, 01:36 PM
CenTexSS's Avatar
If you're in drive, it should shift right around 90mph into 3rd gear at WOT. If you put it in manual mode in 2, it'll go to right at 100mph in 2nd gear.
Old 04-24-2009, 01:44 PM
Striker's Avatar
Im curious to know. My old man has a gxp that he drives back and forth to work, 95% highway driving.
Old 04-24-2009, 01:59 PM
impala06ss's Avatar
EDIT: ~46,000mi
I've noticed that when DOD engages, the transmission disengages and re-engages to smooth out the transition, you can see it on the tach. Anyone else notice that? Also, if you touch the gas under certain circumstances while the DOD is engaging, it will hard shift.
LOL... "suspect it to fail soon"...option....LOL
Old 04-24-2009, 03:07 PM
Honey Badger's Avatar
My GTP (Same tranny, car was putting out a little more power than a GXP GP) was starting to go at 70k. It'll be gone in the next 5k.
Old 04-24-2009, 06:32 PM
JC05GXP's Avatar
Mine is still running fine also 43kmi(knocks on wood)
Hey Miranda, I see you joined over here now. Tons o' knowledge here.
Old 04-24-2009, 08:13 PM
StealthV8's Avatar
I've got 92000kms and just got the trans oil and filter changed, other than that its all good. And i've had the temps up buy 225-240 so many times i lost count, no burnt oil or anything
Old 04-24-2009, 09:46 PM
LS4_SS's Avatar
I'm at 70k now and mine is starting to slip in the cold and going up hills from a dead stop. I'm pretty sure it is valve body, but it is still nuts.
this transmission sucked in my 240 hp GTP, so it's a good thing that GM decided to put it in a car with 60 more hp.
Old 04-24-2009, 10:06 PM
TiredGXP's Avatar
84,000 km and counting - no problems yet.
Old 04-24-2009, 10:13 PM
steveman0018's Avatar
i think GM weakness is the tranny. My dad has the b-body 96 impala, blown tranny at 100000 miles, he then had a 99 tahoe, tranny started slipping at 80000. I had an 01 grand prix gt, tranny started going around 90000 miles. my step dad has an 05 GXP, tranny replaced at 45000 miles..
Overall, My family has had bad luck with GM trannys.. The only one that lasted was an 91 caprice classic and it had 170,000 miles on it when he traded it in and we pulled a boat. No tranny problems at all..
Old 04-24-2009, 10:32 PM
LS4_SS's Avatar
my 95 monte calo Z34 went at 80k
my 01 gtp went at 75k
and my 06 Impala SS is going at 70k
Old 04-24-2009, 11:15 PM
Striker's Avatar
My old man is looking at replacing his oil in it very soon. He wants to know whats the best fluid out there to use or should he just go with OEM fluid?
Old 04-25-2009, 10:36 AM
IAGXP's Avatar
I have 67k on my 06 GXP and just had the fluid changed and had a cooler installed. The existing fluid wasn't burnt but it seems to be shifting better with the new fluid.
Old 04-25-2009, 11:55 AM
Striker's Avatar
So what fluid do you guys recomend? Also for those that have installed a cooler, did you notice a drop in the trans temparature?
Old 04-25-2009, 11:56 AM
Mgpeagle's Avatar
I replaced mine at 64 - 65 thousand miles. My trans. went bad at 48 thousand miles but I nursed it until the 64 thousand mile range.
It had a scortched 2nd gear drum, bad clutches, and a clogged valve body. The new one seems to get really hot so I am sure i'll be changing it again sometime. Oh, and this is driving like a grandpa and all that still went bad. These transmissions suck in the V-8's!
-Mike
