auxilary input for a gxp
Old 01-10-2010, 10:27 AM
Sittingmongoose's Avatar
Default auxilary input for a gxp
Anyone know of a way to get an auxilary input for a gxp. I have the one with nav and i want to add an aux in to it.
Old 01-10-2010, 12:09 PM
I found these two, hopefully they will work. I am thinking of getting the one from crutchfield.
http://www.crutchfield.com/p_469GM12...v2.html?tp=422
http://cgi.ebay.com/Peripheral-iSimp...#ht_2823wt_939
Old 01-10-2010, 12:12 PM
nmp0098's Avatar
If you just want an auxilary input and not an ipod interface, this is only $50:
http://www.pac-audio.com/productDeta...&CategoryID=24
You just select the XM band and flick the little switch (mine's in the little cubby under the heater controls) and voila, aux input. You'll have to buy your own RCA to 3.5mm adapter (amazon.com has them really cheap), but for $50 I wasn't complaining. pac-audio has a lot of cheap adapters for audio stuff.
Old 01-10-2010, 12:37 PM
imnmbr1's Avatar
I just bought a pac wonder how good the other ipod ones work like he listed I wonder how well you can control the ipod
Old 01-10-2010, 12:42 PM
GXP25's Avatar
http://forums.corvetteforum.com/c6-c...-link-pal.html
Old 01-10-2010, 01:55 PM
nmp do you have the nav and monsoon system?
Old 01-10-2010, 03:49 PM
GXP25's Avatar
Huh?
I have the NAV and Monsoon system. I do not have XM. I'm in the process of trying to add the factory XM.
I've been in contact with Ray Kawal and the GM PAL should work just fine in our GXPs with NAV and XM. He has fabricated a harnesses which makes it a simple plug and play process for connecting the PAL to the XM receiver.
It's the most OEM solution out there. Well, it is the OEM solution, lol
Old 01-10-2010, 06:01 PM
nmp0098's Avatar
SM, no I don't. I have the in dash 6 cd changer Monsoon system and factory XM module. The device I listed requires a factory slave unit, which is what a factory XM module is (external cd changers are too). If you don't have XM, then you need this one which costs $100:
I don't have an ipod though, and if you want to control your ipod from the dash then using GM's PAL (what GXP25 put up) looks really good. If you don't have XM though (or some other external slave device), you'll need to get the PAL reprogrammed by a dealer according the that guy's FAQ.
Old 01-11-2010, 08:48 AM
jlwcca's Avatar
I have an adapter I used on my factory set up before going aftermarket.
It includes adapter to factory unit,
Provides clear sound and also charger.
Not sure if it will work on your nav, but I don't see why not.
If your interested pm me, the adapter is just sitting around collecting dust.
-Jason
Old 01-11-2010, 01:47 PM
i tried that 100 one and it didnt work, it just turned my cd to say xm and thats all.
Old 01-11-2010, 03:37 PM
SigmaX6's Avatar
I unfortunately went the Best buy route and got there fm transmitter. I was very hesitant to get it. but a guy there had a grand prix with it installed and showed me how it worked. I got one installed the week after (140 bucks). It uses a fm transmitter but its clamped down onto your antennae and its never conflicted with any radio stations with no background noise at all. Only works for i pod though.
Old 01-11-2010, 04:58 PM
nmp0098's Avatar
Sorry to hear that. Did you call PAC to see what they thought was going on?
Old 01-11-2010, 05:31 PM
nope but i did just email ray kawal
Old 01-12-2010, 12:57 PM
nmp0098's Avatar
If had an ipod that's the route I would go too. I just have a Sansa Clip because the top of the line model is $40 every Christmas and I couldn't put all of my music on an ipod anyway.
Old 01-13-2010, 01:15 PM
ya apparently no one knows how to help because i talked to both ray and someone ray directed me to and neither were any help. I guess i am going to have to buy a bunch of different ones.
Old 01-14-2010, 09:26 AM
GXP25's Avatar
That's because they have Corvettes; they're not going to hold your hand through it.
Now let's carefully examine the [top of the] PAL:
Notice anything familiar? Auxiliary inputs!
I'm going to make it easy: buy the GM PAL, buy Ray's harness, and then buy an RCA to 1/8th inch/3.5mm adapter.
Now in picture form (with hyperlinks!):
Buy the GM PAL (P/N: 17800593 - $137.59 from GM Parts Direct):
Buy Ray Kawal's harness (One plugs into the PAL, the other into the XM unit. The cable that was originally plugged into the XM unit plugs into the female connector at the Y end of the harness.):
Lastly, buy an RCA to 1/8th inch/3.5mm Y-adapter, either male or female (you have four options on that page; 12ft male should be adequate):
It should be clear sailing from there. No dash or head unit removal.
The biggest headache might be finding a path for the cable to the center console.
Old 01-14-2010, 12:56 PM
Why wouldn't i have to remove the head unit? I don't have an xm receiver does that matter?
And thank you for holding my hand through this I am just being careful because i didn't want to deal with buying another aux unit and not being able to return it when it doesn't work. So this time i am doing research.
Old 01-14-2010, 08:56 PM
GXP25's Avatar
Ah, then you are in the same predicament as I.
You need the XM reciever (bought mine for $35 on car-part.com P/N: 10367164), receiver bracket ($23.34 from monsterpartsonline.com), cable ($23.77 from monsterpartsonline.com), and the antenna assembly.
I think we could use the existing antenna assembly. I just cannot figure out what cable is used (or which one is needed) to connect the XM receiver to the head unit/NAV.
The cable in the illustration does however look like it has a Y terminal to facilitate the merging of the head unit/NAV antenna connection with the receiver's.
Old 01-15-2010, 11:16 AM
ok well me an my friend are working on a free way lol if we cant get it i guess i am going shopping. I already got something pretty cool working
Old 01-18-2010, 02:48 PM
imnmbr1's Avatar
Gm told me that the pal box isn't compatible with a grand prix. - would like to find someone who did it. Maybe I should be a guinea pig on this.I have nav and xm.
Quick Reply: auxilary input for a gxp
