Exhaust
Exhaust
Is magnaflow the only exhaust made for these Impala's? I want to look into getting a new exhaust but magnaflow isn't loud enough for me. Any suggestions?
The consensus is that any of the V6 W-body exhausts will fit with some relatively minor modifications to the mounts and trimming/adding short sections of pipe.
You could also get one custom made and put louder muffs on em'. But that might be a little more $$. Or you could keep stock piping and put different muffs on it! That is the cheaper way to go LOL
In that case I'd order a bunch of pipe from Summit or Jegs and make my own system. Much cheaper.
it doesnt make a big difference with the res deleted but u will definitely notice it as far as stock piping goes. I want it to sound like its a big block in there lol
I'd do a 3" system, Y it into 2 2.5" pipes with spintech mufflers. If ground clearance isn't an issue put the spintech where the resonator was and run the pipes on back.
they just did a header group buy you might even still be able to get in on it. if you want it loud run the headers and put the res back on and run straight pipes no mufflers. should be pretty loud.
i saw a video on youtube this guy had a 06 impala ss i believe and it had no mufflers and it was loud as hell. but i want my car to pass inspection. i also want this damn rev limiter off! i hate this damn thing
