Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Transmission Guides
- Camaro How to Change Automatic Transmission Fluid<br>Step by step instructions for do-it-yourself repairs.
Trans Fluid change?
Trans Fluid change?
Hey everyone,
Well I'm a sort of new owner (Bought Oct 2010) of a 2007 GXP. I bought the car with 49k miles on it, it now has just over 57k (we do a lot of highway driving). I've changed the oil twice now (once the day I bought it) and haven't gotten around to the trans fluid yet, although when pulling the dipstick it looks nice and red and the level is perfect. I have no idea if the previous owner ever did a trans service, but judging by the color it has to have been done at some point. I HAVE had the car do the wierd slip-catch thing from a stop at least once, but otherwise the car seems to drive and shift perfectly. I have an aftermarket warranty on the car and I'm hoping that I can get them to replace the trans in this thing at some point before it expires (at 94k miles). Should I do a trans service on this thing? Or should I just drive it and hope it blows by 94k? I've read a lot about the trans issues everyones been having on these cars and it makes me real paranoid, but when I drive it it really seems ok. Thoughts?
Personally, I would just ride it out until it blows because when it does, you will have a new transmission. If for some reason the flush were to help the tray survive the miles, at 96k it would go out with our luck.
Also, Great Quote!
Also, Great Quote!
Hey everyone,
If you do the service yourself, take pictures if you find material in the pan, and save the material. You can show it to the shop that does the work and they can use it to help get the thing warrantied, if necessary. Also, save your receipts for the fluid and filter you buy.
And I'll add you to the list of people who've experienced transmission anomalies.
i know this is an old post but I am currently trying to change my tranny fluid
I went to the dealer to ask about the tranny fluid flush and replace with new oil but they dont replace the filter gasket pan something .....and another shop told me that if I had my fluid replaced that the proper way is to service everything not just the tranny fluid who should i go with please help me decide
should I go with the deaaler or with the shop that says they will service the pan and oil gasket etc...
From what I've read, the proper way to get the trans fluid changed is to have them drop the pan, replace the filter AND pan gasket, then re-fill it with fluid. Make sure that they use Dexron VI, though, as if they use the wrong fluid, you're trans is toast.
Still haven't done mine and I just rolled over 60k miles. Trans is starting to feel funny if I hit it more than about 1/4 throttle after slowing down a bit (like if someone is turning in front of me, etc.). It likes to go BANG when it downshifts. Hooray for GM's 100k powertrain warranty!!
Our pan gasket is reusable. I would have the pan dropped, filter replaced and only if needed replace the pan gasket. I reused mine the 1st time and I'll see how it looks the 2nd time in a few weeks when I do the tranny service again.
Its not hard at all to do, and takes about 8qts to fill back up and depending on cost of fluid should be around or under $100 total. I do mine every 30kmi or so.
Did you Clear the Fluid in the radiator too? And has anyone used the MAX ATF from Royal Purple? My fluid Is starting to brown a bit and its slipped Probably once or twice going up a small grades. 06 GXP
Edit; Royal Purple is NOT recommended in DEXRON-VI Via the website. Sigh
