installation of tep trans cooler
I only looked under my car once. I only saw the one fitting for the cooler line facing front of car. Is there a plug or fitting that is right beside the other one which faces straight up that I missed? How the Hell do you mount it horizontily ? Now I dont have enough braided line to reach back to the trans if both trans lines mount an inch from eachother and wasted money.
1 Post
Since you have the inline cooler you'll be tapping into your existing cooling system so you shouldn't be connecting to the transmission. That's my guess as to why you're short. And if you're confused on line routing and mounting the cooler you can email Dave and ask for his installation instructions.
Moderator
Also FYI you can use a -6 hose connector with 3/8ths trans or fuel line.
1 Post
Nothing special about the fittings at all of you read that link I got you, you could see the fitting is just a regular old -6 on the trans side as for the cooler you could probable roll with a 3/8th to -6 adapter and finish it out..
Moderator
I out lined the different doorman pan for 30 bucks in that other thread I linked. It comes with a drain plug installed already, however be prepared to get your hands a little dirty not to much though. Just loosen the bolts on the passenger side first. Have your pan ready and then start loosening the driver side pan a little. Whatever you do not let the pan hang by a bolt. You will warp it. No rtv is required just reuse your factory one
