Catch Cans??? WHY???
Old 09-12-2013, 09:21 PM
08 pimpala ss's Avatar
Default Catch Cans??? WHY???
I am just wondering why it seems that almost everyone who has done a intake swap on here is using catch cans so i am in the process of the intake swap what is the benifet of them? Dumb question probley but i really would like to understand thanks guys??????????????????????????????:confu sed:
Old 09-12-2013, 09:55 PM
Moderator
91parkave's Avatar
https://ls1tech.com/forums/ls4-perfo...n-install.html
Old 09-13-2013, 05:36 AM
fieroguru's Avatar
Short answer is it helps keep oil out of the intake...
I need to check mine to see how much oil it has collected in the last 5K miles.
Old 09-13-2013, 09:20 AM
Moderator
91parkave's Avatar
Lol I kno I need to check mine as well. I tried experimenting with the air oil separator but that filter element they use is to restrictive
Old 09-13-2013, 12:09 PM
LS1 Racing's Avatar
Mine collects a shot glass worth of oil every 1000 miles. Adding the catch can eliminated the smoke problem I was having, so it was well worth the small effort that it takes to install.
Old 09-13-2013, 04:41 PM
x11 nut's Avatar
Take your throttle body off and wipe you finger inside the intake snout - it'll be self explanatory... Catch can keeps intake from getting filthy.
How's the swap coming?
Old 09-13-2013, 08:42 PM
Thanks so much guys for. Clarifying
Old 09-13-2013, 11:36 PM
And it's coming dropped my vlom off at the machine shop today to be modified should get it back tomorrow and if I get those pig tails I can test out the ls1 tb hopefully it will work and I ordered new runner gaskets and they only sent me 7 wtf other than that if I get everything by monday and don't get busy at work it will get done ill post pictures of the ls1 tb and spaceer setup as soon as I confirm it working
Old 09-14-2013, 01:58 AM
Moderator
91parkave's Avatar
Lightbulb
If you have HP tuner where you can readily modify your tune then go for the tb swap otherwise you night have some issues for plug and play. Also giving that the tb opens up in reverse of the ls1/6 tb so you might go into reduced power mode. Ibwould be working on an adapter if I were you just in case.
Old 09-14-2013, 07:53 PM
By adapter u mean ls6 to ls4?
Old 09-14-2013, 10:04 PM
Moderator
91parkave's Avatar
Yes, throttle body adapter
Quick Reply: Catch Cans??? WHY???
