Ls1 throttle body on ls6 intake installed today
So today i finally finished my project ls6 intake and ls1 throttle body the tb was a pain in the @#$ But i got it running thanks to a few people on her x11 nut and 91 park ave ill post a video in a bit but it all runs great after extensive tuning it took about 5 hours today to get everything right
link to you tube video
Good job man !! Glad to see it done - should put the "we can't use LS1/6 throttle bodies to rest"!!
Looking forward to seeing the LS7 MAF added, then we'll have to do a night at Moroso..
Yes and i got alot more pics and stuff to post after everything is all said and done still have clean the wiring up re lume all the crunchy bs and the wiring is a must becouse thats what i do for a living so it my rep but everyone who has seen it so far loves it!!! And holy **** what a differnce with the intake and tb all tuned in i would say the car is 30% faster
I'll post the wiring schematic and some pics of the harness when I get home later. Once you have the wiring pigtails it's pretty straight forward rewire. Well, long as you follow diagram and don't question the pin signal - the TPS low & 5 ref have to be swapped for each sensor because the TPS is on the opposite side of TB for LS1 vs LS4.
I'm waiting to see what 08 Pimpala's tuner adjusted to get it sorted. Just plugging it in it will open and cycle the throttle blade but after short drive it'll set codes for TB, so TPS vs airflow values have to change for sure.
Moderator
LS4 - LS1
A. C
B. E
C. A
D. F
E. 2 pin A
F. 2 pin B
G. B
H. D
Here's a few snaps and video of when I tested the harness. Also, a cleaned up pin out chart - it has info for LS1 & 6 TB (listed as Vette) and the Truck TBs that also work with LS1 & 6 intakes.
http://www.youtube.com/watch?v=dfwUm...ature=youtu.be
So is anyone else out there gonna try this mod with the tb it is by far between the im my best mod so far the response the ls1 tb has is unlike no other
Well to break it down i paid 300 for the intake man 175 for railks and injectors 100 for the throttle body 60 for vally cover mod and i also counted the ls7 maf 45ish air straightener 40 and other odd bs like 50 for the tb spacer so that backwards *** tb would fit **** adds up quick
