How to tell if your Rack and Pinion is bad
Hey guys, do any of you know how to tell if your rack and pinion is shot. Right now I can't tell if its the rack, or my cv joints. I hear popping sounds when i turn the wheel in either direction, and when traveling on an on-ramp for a highway, its difficult to turn.
Anyone with experience in this?
It's my CV joints i'm almost sure of it. There is grease on my drivers side. Well I'm going to just do them when I throw in my new struts. It clicks when I turn, and it feels "heavy" when I corner.
LS1Tech Sponsor
it's the CV joints...
and on these cars, you have to replaced the whole front axle assemblie's for that issue...
have done it 3 or 4 times now
and might as well replace the wheel hub assemblies as well while that's being done and parts are all off.. I'm sure the bearings are about done, unless you have really low mileage on that car....
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
it's the CV joints... and on these cars, you have to replaced the whole front axle assemblie's for that issue... have done it 3 or 4 times now and might as well replace the wheel hub assemblies as well while that's being done and parts are all off.. I'm sure the bearings are about done, unless you have really low mileage on that car....
Moderator
timken or SKF,hpnestly if your bearing have no movement at 12 and 6 oclock then dont replace them. just keep them on hand for when they do go bad which they eventually. for Cv axles just dont go to advance auto parts. there notorious for splitting boots. duralast golds from autozone are what i have with no issues along with a lifetime warranty
LS1Tech Sponsor
I went with genuine GM parts.... GM front axle assemblies, and GM front wheel hub assemblies... have to do the full assemblies, can't just do the bearings or cv joints on these cars...
and at 128k, yeah I would definitely replace them, especially if you don't know if the previous owner ever did or not...
you can find genuine GM parts at newgmparts.com
and yeah.. while everything is pulled off already to do the axle assemblies anyway, might as well replace the wheel hub assemblies too and save yourself some time/labor charges...
__________________
I went with genuine GM parts.... GM front axle assemblies, and GM front wheel hub assemblies... have to do the full assemblies, can't just do the bearings or cv joints on these cars... and at 128k, yeah I would definitely replace them, especially if you don't know if the previous owner ever did or not... you can find genuine GM parts at newgmparts.com and yeah.. while everything is pulled off already to do the axle assemblies anyway, might as well replace the wheel hub assemblies too and save yourself some time/labor charges...
LS1Tech Sponsor
yep.... they're not cheap, heh... cheaper than getting from a dealer though...
__________________
I just bought new bilstein HD struts and ssc lowering springs from zzp. I might have a heart attack!
LS1Tech Sponsor
better quality, will last longer... before I replaced mine again this last time, the 2 times before that, I had gotten the **** from NAPA.. was crap.. lasted about a year before having to replace them again...
but, do whatever you want man hehe... just be aware that you'll probably be replacing those cheap ones again in a year or so....
__________________
Go with SKF! They've actually been engineered properly.
https://ls1tech.com/forums/ls4-perfo...-bearings.html
$~91 each for the fronts.
Go with SKF! They've actually been engineered properly. https://ls1tech.com/forums/ls4-perfo...-bearings.html $~91 each for the fronts.
