10-25% under drive balancer interest?
So I talked BHJ about having a balancer built which they did one for Sam( dude with the Dart 427) turns out they didn't build an entire balancer for him. I guess gm used solid steel and not cast steel for the ls4 balancer hub. So what BHJ did was used the factory hub and made a new inertia ring and used better rubber between the two. He said it would run about $250 to have this done. I also asked him if they could make an underdrive version and he said at that point it would need a new hub as well. So I'm here to see if some people wanna get together and get a group buy/build for the under drive setup or maybe both setups. He said if I had them build a total custom balancer I'd be looking at about $750 give or take a few dollors. So the more ppl we get the better price we get.
He didn't say. He said to get a group together then they would be able to get a price based off the number of people we had. I didn't really think $750 was a bad price since ls1 balancers go for $400-500.
I didn't read your post right lol. He didn't say there was a minimum. just said the more people there were the less it would be. He was willing to do just one for me if no one else wants one.
I might be interested. I have been in communication with PRW for a few months. They have an underdrive version available for the LS4 currently and are almost done with a non underdrive. The guys are out at a show currently. I am waiting to hear back from them so I can get the part #'s and pricing. If they have it, I will probably order it from them since they have been keeping me informed about it through the process.
If someone already has one then I'll go with that. Thanks for the heads up. I'll have to give them a call.
pulleys
ok i found out measurement from prw .984" now he didn't say if that was from block or back of dampener,but it is to center of ribbed part,i bought it and ill try to mock it when i put headers on,gonna drop motor,seems easiest way,because i also have the mounts that i bought from x11 and 91 parkave that I'm gonna put on too.ill call prw back tomm.and get the right info i was driving and cut call short called gm they said truck 5.3 is different part # than fwd 5.3
