ordering cam, what all do i need
Old 10-22-2014, 12:22 PM
2008impalaguy's Avatar
Default ordering cam, what all do i need
hello, its me again with another noob post lol. about to order my cam and was curious on a few things. first off, where should i order my cam from, i was thinking texas speed, but they havent been responsive on my questions, as im a little new to cams and the specs and what not. also what springs should i get. do i need anything else? was going to get a timing chain since well be in there, and will my stock pushrods be fine as long as they are straight and ok.? thank you much
also, will i need new lifters, or will the dod ones work fine
Old 10-22-2014, 07:47 PM
no one lol? not even to help me wtih specs on the cam?
Old 10-22-2014, 11:41 PM
Moderator
91parkave's Avatar
Pat g look him up
Old 10-23-2014, 08:08 AM
not gonna lie, i know nothign about specs on a cam. these are the two that ive been told would be beest for my set up.
thoughts
also. i have dod deleted, the tray isnt even wired up, would i still need to get a non dod tray even if mine wouldnt even be able to be re-enabled?
DUR @ .004" 272*/284*
DUR @ .050" 212*/ 222*
LIFT .551/.551
LSA 115*
DUR @ .004" 276* / 284*
DUR @ .050" 214*/ 222*
LIFT .585/.585
LSA 115*
Old 10-23-2014, 08:54 AM
Moderator
91parkave's Avatar
Pat g recommended those? That's what I'm saying pat g recommends a specific can for you based on mods transmission variables. Etc....he is a cam guru. I'd utilize that resource
Old 10-23-2014, 09:14 AM
just emailed him for further information. our cams are 1 bolt correct. for an 08 ISS
Old 10-23-2014, 09:18 AM
Moderator
91parkave's Avatar
Correct
Old 10-23-2014, 12:28 PM
k i think i got evertying squared away. specd out comp cam. ls7 lifters, ls2 timing chain, gaskets i need, upgraded spring kit. ls6 oil pump. pushrods. think thats everything. i have my tray modified so it wont activate anymore, the dod part is welded up and snesor isnt plugged in. do i need a non dod tray, or becuase everythings been done up from my intake sway will it be good
http://www.compcams.com/Company/CC/c...csid=1089&sb=0
thats the specd out cam
Old 11-13-2014, 02:51 PM
severancej's Avatar
Ever get anywhere with this?
Quick Reply: ordering cam, what all do i need
