Car goes in 2 Speedinc Next week! H/C/I install
Old 11-10-2008, 02:25 PM
AChotrod's Avatar
Default Car goes in 2 Speedinc Next week! H/C/I install
Ok boys and girls! I finally have all my stuff together for My LE2/LE3 set up and all the supporting mods. Waiting to go in!
The Date is set! I will be dropping the car off on the 17th at Speedinc.
They will dyno it stock on the 18th b4 the tear down. Do the build and Dyno tune it when its all buttoned up! Should be finshed right B4 Thanksgiving!!!!!
Wish Me luck!!!!!
Any guesses on HP or 1/4 times
1996 Formula WS6 M6 Hardtop 32,000 miles
LE2 heads with patriot gold springs milled .030
Comp Pro Mag 1.6 7/16 NSA rockers
TFS guideplates
Arp 7/16 rocker studs
MR Gasket .026 head gaskets
LE custom 230/236 cam
LE3 Intake
Delphi 37# injectors
BBK 58mm TB
LPPs LTs ond ORY
B&B cat back
Mez Elec Water pump
autolite 104
MSD plug wires
Speedinc dyno tune
Nitto 315/35/17 DRs
STB
SFC
LCA
PHB
TA
Pro 5.0 with speedinc short shifter
Strange DS
Strange Dana S60, 35 spline, true track, 4.10s
and some other lil stuff I cant think of right now
Old 11-10-2008, 02:29 PM
LS1 SPEED's Avatar
see you soon
Old 11-10-2008, 02:30 PM
97T/A's Avatar
how much are they charging you for the whole installation?
Old 11-10-2008, 02:31 PM
AChotrod's Avatar
alot!!! Talk to Larry!!!
Old 11-10-2008, 02:32 PM
EliteCamaro94's Avatar
also interested in how much its costing
Old 11-10-2008, 02:39 PM
Racin96ss's Avatar
You should be very happy with the results...Nice seeing these low mile hardtops getting work done now a days!
Old 11-10-2008, 02:40 PM
LS1 SPEED's Avatar
if someone needs pricing for an install they can email me
Old 11-10-2008, 03:24 PM
joeZ96's Avatar
Speed Inc. just finished installing LE2 heads/intake for me couple weeks ago. We saw some really nice gains on the dyno with just the small hotcam that I'm running, and even nicer gains on the bottle Keep us posted.
Old 11-10-2008, 04:18 PM
Taubr Unit's Avatar
hey larry, can you guys tune obd1 cars now? Last time i talked to you, you didnt have the program up and running or it was down. Can you do it now?
Old 11-10-2008, 04:22 PM
LS1 SPEED's Avatar
We are still using Ion as needed. We do not see enough OBD1 cars to reinvest in the software at this time. I just worked with Ion this past Sat for 3 cars and have always been happy with his services.
Ion will not be back out this way until spring, but keep in touch and we can try to get you here with him.
Old 11-10-2008, 07:53 PM
AChotrod's Avatar
God Bless OBDII! Can be tuned and easily passes emissions when tuned!
Old 11-10-2008, 08:02 PM
dsmawd350's Avatar
ehhh my speedensity car was tuned easuly enough...put down 415/368 with a cc306
Old 11-10-2008, 08:19 PM
AChotrod's Avatar
Im hoping for the same! Well see soon!
Old 11-10-2008, 08:49 PM
BOLO's Avatar
AChotrod, looks like a nice recipe for power you got there. And you came to the right place to make it work. Hopefully, you'll be able to run it before oldman winter comes are way.
Old 11-10-2008, 09:02 PM
strokin93z's Avatar
Sounds Awesome keep us updated. Goodluck
Old 11-10-2008, 09:11 PM
BADHAWK51's Avatar
Larry and the guys can do some amazing stuff with the old LT1. I'm going back to a 4L60E with a yank pt4400 stall and hoping to see some 10's na with my LT1 junk.
Old 11-10-2008, 09:14 PM
AChotrod's Avatar
I pray to get it out this year!!! Was that you in the maroon Z on the 1st?
Old 11-10-2008, 09:15 PM
AChotrod's Avatar
You will get it there! I hope to be as fast as you guys soon!!
Old 11-10-2008, 09:32 PM
BADHAWK51's Avatar
The best advice I could give you is know what you goal is et wise and talk to Larry about a plan to get you there. I changed my mind so many times it cost me more than most.
Old 11-10-2008, 09:37 PM
C5042081's Avatar
sweet.....make sure you post some sound clips of it after its done
Quick Reply: Car goes in 2 Speedinc Next week! H/C/I install
