New and lloking for info for my lt1
Old 11-19-2008, 09:49 PM
94BlueZ28's Avatar
Default New and lloking for info for my lt1
Hi everyone, I just thought I would stop by and introduce my self....My name is steve and I'm currently stationed in warrensburg, Mo working on the B-2 bomber...Besides that crap I would love to gain some more knowledge pertaining to my LT1 engine. I would appreciate some opinions on what route to go with the car. I was thinking either a 383 stroker LT1 or a 396 stroker Lt1. I've heard good things and bad things about both. I would also like to have recommendations on a cam swap. This is what I have done so far....Lt4 hotcam, small in my opinion and not aggresive to me, BBK shorties, 85mm MAF, 58mm BBK TB, 32 lbs injectors, cold air with vortec elbow, shift kit, 3:73 gears and a tuning done by mad Z28. I want a more radical, aggressive sound to it and I want the biatch to come alive and make you wonder what it has, suggestions for the new guy would be great!!!!Thanks
Old 11-19-2008, 10:00 PM
lt1z28camaro's Avatar
Get a stall on that thing! Many will recommend getting your heads ported and a more aggressive cam. elliottsportworks.com and advancedinduction.com are both great places.
If you're wanting to stroke it, get a forged 383. I personally wouldn't go over that.. There are many many different options to go with once you get into that area! Good luck!
Oh and WELCOME! haha.
Old 11-19-2008, 10:04 PM
94LT1Bird's Avatar
screw the hotcam....its worthless.....hardly any gains...if u r gonna takethe time to do a swap.....put in a bigger cam
Old 11-19-2008, 10:05 PM
94LT1Bird's Avatar
and screw shorties....get long tubes
Old 11-19-2008, 10:10 PM
Elliott's94Z's Avatar
It's far from worthless there champ. It's been a great running cam for what it is. And bigger doesn't always mean better in certain situations.
Lloyd Elliott works wonders for our LT1's. Does great head work and his custom cam shafts are nice as well. http://www.elliottsportworks.com/
Old 11-19-2008, 10:13 PM
Look into LPP long tubes (if there are still any avil). Awesome header for the dollar. They will really open your car up especially being you already have a cam and want to build her up
Old 11-19-2008, 10:15 PM
AChotrod's Avatar
Defenitly contact Lloyd Elliott! Great guy to work with and everyone using his stuff is more than happy!!!!
Old 11-19-2008, 10:18 PM
AChotrod's Avatar
Oh yeah and the LPP Lts rock for the cash!!! I know of a few really fast cars running them like Casper383 and LS1 Speed. They are $1500.00 headers for $550
Old 11-19-2008, 10:21 PM
$550 shipped!
Old 11-19-2008, 10:36 PM
X2 on the long tubes, even with mid lengths there is a noticeable difference, and LPP's are a great header, don't know what the availability is on them recently though.
Old 11-19-2008, 11:52 PM
SoxXpupPeT's Avatar
full exhaust long tubes X pipe dumped at the axle for the hell of it. solid mechanical cam, stall, gears have some fun
Old 11-20-2008, 12:34 AM
CamaroRacing12's Avatar
i wish i waited for the LPP headers... instead i got pacesetters
Old 11-20-2008, 01:04 AM
chavez885's Avatar
Welcome to the site Steve, lots of good info and bad as well. The 1st steps i would take if I were you would be.
1. Get longtubes
2. Get a stock MAF back on there
3. Get a stall.
THEN, get a custom ground cam with appropriate springs and get the thing re-tuned. How many miles on the car steve?
Old 11-20-2008, 08:26 AM
MonmouthCtyLS7's Avatar
What are u talking about, its a mild emmisions cam but there is gains there...similar to the 305/503
Old 11-20-2008, 08:57 AM
Exactly...for a emissions cam it's one of the best out there...next to Lloyd's Emission style cams This kid has no clue is what it boils down to
Old 11-20-2008, 08:47 PM
94BlueZ28's Avatar
Well we are straight to the point on this forum for sure! One question the caught my intrest is, going back to a stock MAF....Why would this be better??? I always liked the 306 comp cam for the LT1, well it least the sound, but I hear there alot better performance cams out there. What's the biggest cam I can go in this forged 383 stroker setup??? Emissions on the other hand, I don't have to obey the emissions thing considering I'm a resident of Illinois. No isnspections there. So go with Long tubes for sure! Oh to add, my heads are have already been ported and polished and had a 3 angle valve job done from a local machinist in Tucson, Az. I'm in it to get the best performance available for when the time comes this spring to rip the motor out. So Please all suggestions are great! Thanks steve
Old 11-20-2008, 08:51 PM
94BlueZ28's Avatar
Also the car has 173K on the bottom end and about 600 miles on the top end. Mostly high way miles and I'm sure you've all heard this but the guy before me used to drive it to car shows all the time and that was back in 1999 when I bought the car I'll post pictures later after it gets out of the shop. Changed out the hood after the other one flew off about 80 mph
Old 11-20-2008, 08:54 PM
Doc Mitch's Avatar
Ditch the MAF you have and go back to stock. It's a lot harder to tune with an aftermarket MAF
Old 11-20-2008, 11:42 PM
BLK,97,T/A,M-6's Avatar
With an auto, I think thie biggest bang for the buck are gears, and a good hi stall converter. If your pockets still have some cash in them after that, go for a set of heads. You will hear Lloyd Elliot and Advanced Inductions a lot, and they are good products by all the testimonials, but I like the AFR eliminators. AFR's are designed from a clean sheet and are not bound to the constraints of stock castings. They feature many new advancements in the springs and valves.
Old 11-21-2008, 12:12 AM
1. long tubes, ory
2. stall, 3.73's
3. custom grind cam
4. s60 rear end
5. forged 383
6. 150 shot
That would be a rather quick car. Take it a step at a time, sounds like you're about ready for a bottom end with those miles.
