Whoa is me
Old 11-30-2008, 09:27 PM
Pretyflywiteguy's Avatar
Default Whoa is me
I charged my battery last night on a trickle charge because i've been having problems with it holding a charge over night. This morning when I went to leave to go to work NOTHING worked. No interior lights, dash lights etc. It might as well not have a battery in it. What could I have fried?
I unhooked the battery and put it on a load tester and its reading 12 volts and 500 amps without load.
funny thing, this battery is less than 6 months old.
Old 11-30-2008, 10:02 PM
Formula350's Avatar
Try tightening the posts better? Common problem. That or check all the grounds and power leads to make sure there's no corrosion or loose connections.
Old 11-30-2008, 11:38 PM
their tightened to the point they start to strip..
Old 12-01-2008, 12:04 AM
Village Troll
SS RRR's Avatar
start checking fuses
Old 12-01-2008, 12:38 AM
checked all of them, one by one with a continuity meter. All are good.
Old 12-01-2008, 12:51 AM
Finally got the car to start. Don't know how.. but it fired. Gauge in the dash is reading about 13 volts.
To add, the positive battery cable is very hot to the touch and so is the posts that all the electric componants in the car connects to. I held my hand about 1/4 inch away from the posts and could feel the heat. I unplugged my stereo stuff but I'm not sure if that might have changed things.
Old 12-01-2008, 03:23 AM
Formula350's Avatar
Too much resistance in the cables. Generally caused by a bad ground or bad cables.
Old 12-01-2008, 04:31 AM
the_merv's Avatar
Yea, there is a problem with the Circuit continuity..
Old 12-01-2008, 09:00 AM
camar0corey's Avatar
Woe....
Old 12-01-2008, 03:42 PM
I hate electrical
Old 12-01-2008, 03:49 PM
LTBANDIT's Avatar
should you disconnect your battery before charging it? i do but i don't know if it is manditory...
Old 12-01-2008, 04:46 PM
I don't think it matters but I do because it's easier to have it out on my work bench next to the load tester than leaving it hooked up in that tight space and trying to hook everything up.
Old 12-01-2008, 04:48 PM
Well i unhooked all my stereo equipment and the post is still hot.. I guess I need a new batter cable? should i got junkyard hunting or get one from advance?
Old 12-01-2008, 05:02 PM
Battery cables are cheap. Might as well go new.
Old 12-01-2008, 05:06 PM
45" or 55"?
Quick Reply: Whoa is me
