Unplugged the o2's....
Old 12-21-2008, 11:36 AM
grnmonster's Avatar
Default Unplugged the o2's....
Have a misfire i think its the o2's (seeing as i have replaced everything else) so i unplugged them and it does not seem to be running any better...does that means it cant be the 02s? the misfire comes in and out one moment it will be perfect next minute it will miss..and its not throwing any codes.
Old 12-21-2008, 11:47 AM
lt1 beast's Avatar
try pulling the o2 see if they are clogged if not clean them with brake parts cleaner and reinstall that way you know your 02 sensors are ok
Old 12-21-2008, 11:54 AM
grnmonster's Avatar
Forgot they are brand ne bosch o2's
Old 12-21-2008, 12:22 PM
vanilla89's Avatar
from what I hear bosh suck.. Get some ac delco..
And you don't want to clean them with brake cleaner eather, if they are that bad,BUY NEW ONE'S
Old 12-21-2008, 01:06 PM
grnmonster's Avatar
Ya that seems to be the general consensus ...bosch sucks...guess ill have to track down some delcos
Old 12-21-2008, 04:02 PM
shbox's Avatar
Unplugging stuff is never a good way to test on a computer controlled car. There are too many inputs and variables that affect things. The Bosch O2s don't have such a good track record on LT1s, but some people get by with them.
Old 12-21-2008, 04:05 PM
LT1PwrdZ's Avatar
Bosch is fine. We sell plenty. I have had them on my car with never any problems. Just my opinion as a parts guy.
Old 12-21-2008, 04:20 PM
LS1 SPEED's Avatar
We have never had luck with 02 sensors other then GM.
have you looked a the plug wires?
how old is the Opti?
have you check to make sure the fuse is not blown? I believe it is for both the MAF and 02's, but could be wrong.
Old 12-21-2008, 06:28 PM
grnmonster's Avatar
New plugs and wires, OPTI is less than 6 months old, i have not checked the fuse ill do that, i just think its the 02s becuase i had this same probblem about 2 weeks ago and replaced the 02s and it fixed the problem temporalily...now im on my second set of boschs (under warranty)
Old 12-21-2008, 11:22 PM
grnmonster's Avatar
Bump....
Quick Reply: Unplugged the o2's....
