How to jack up motor for oil pan gasket
#41
Alot of people had problems even after following the sheet. I realize what the sheet says. I think it requires just a small bit. Have you performed this job successfully?
"I installed it completely clean and dry and never had a problem with it. I applied a very little amount of RTV where the Timing Cover and the Block meet, and the same on the Rear Main Seal Bracket."
-The Merv
another thread where problems occurred after a dry installation:
http://www.camaroz28.com/forums/arch.../t-615529.html
