help with cam and valve springs
need help determaning what vlave springand cam i have in my old motor got car with bad bottom end and have no idea what is done to moter ecept it have some type of dual valve spring and guideplates and ported and polished heads and intake i can take pics to help explain what im talking about
Im not sure, but i thought even the stock cam had some kind of number on the end of it, maybe someone else will chime in.
You probably wont ever find out what kind of springs you have, but if your going through the trouble of rebuilding the motor id definitly put new ones in. Did it have roller rockers or stock stamped rockers?
Im just wondering why someone would use a stock cam in a motor with pp heads.
