can i put a t56 from a 06 gto into a 94 z28?
Old 01-14-2009, 05:20 PM
johnnyar15's Avatar
Default can i put a t56 from a 06 gto into a 94 z28?
i have a 94 z28 with a rebuilt 4l60e, it has a shift kit and torque converter, and im still not happy, so i started looking at a t56, then i found 1 from a 06 gto, so will it fit?? and what is better a t5 or t56, i like 5 speed better but everyone insists on the 6 speed. so everyone's input will be considered. thanx.
also ima put all of this into a 89 camaro, i like 3rd gen. better. but before i pay 2 put everything into the 89, i want to know what should i do with the tranny. so i dont have to pay more to do the conversion.
Old 01-14-2009, 05:46 PM
93lt1M6z's Avatar
the t-56 out of the gto will be different. the input shaft in a different length then that from the 93-97 styles. theres another difference i forget what.
also to put it into the 3rd gen with the lt1 you need a new crossmember, and i think you have to mess with the engine mounts. also theres the wiring, so on and so forth
Old 01-14-2009, 05:54 PM
LT1
LT1's Avatar
The GTO T56 will not work. Find a 94-97 T56 from a fbody. The 93's are rated for lower HP.
Old 01-14-2009, 05:57 PM
nik1703's Avatar
yeah, not worth it. just buy a GTO. lol
Old 01-14-2009, 05:59 PM
johnnyar15's Avatar
well that sucks for the t56 there is no other way to make it work??
and for the 89 camaro, ima use my engine, tranny(hopefully a standard) wiring harness, rear end, what else would i need?
what do u think about the 5 speed vs 6 speed??
Old 01-14-2009, 06:03 PM
camar0corey's Avatar
Use the six speed. T5's are weak, T56's hold up to a good amount of power. As stated shop around and find a t56 from 94-97.
Old 01-14-2009, 06:59 PM
johnnyar15's Avatar
ok so what about the conversion to the 89 camaro? i will put in my lt1, tranny (need a t56, so now selling my 4l60e), wiring harness and rear end, what else should i get before the conversion??
Old 01-14-2009, 07:36 PM
93lt1M6z's Avatar
custom crossmember that will fit a 3rd gen for t-56 (shop around they make em). here is a good article for ya
http://www.thirdgen.org/techboard/lt...want-swap.html
Old 01-14-2009, 08:45 PM
marc97taws6's Avatar
If you can make the t56 work on the 3rd gen, do it!
T56's are STRONG transmissions and the 6th is also amazing for gas mileage unlike my A4
I generally don't like 3rd gen's as much as 4th gens.. unless if you have a beautiful IROC-Z..
GTO would be nice also for comfort, practicality..
Old 01-14-2009, 08:51 PM
LT1
LT1's Avatar
Only 5 speed worth putting in is a TKO 500, TKO 600, TKO 600RR rated at 650hp
The world class T-5 is rated only for 265hp
Old 01-14-2009, 09:13 PM
johnnyar15's Avatar
thanx, i was wondering wat 5 speeds could i put into my car, t56 is a good tranny, but i hear to many bad things with people who have them, i was with my friend in his trans am wen he raced, he did not even get to 5th gear in the race, so i dont see the whole point, unless someone can point it out to me. plz someone help, but do the tranny's that this guy ^^^^^say really work well??
Old 01-14-2009, 10:04 PM
the_merv's Avatar
Yea, the GTO one will be more work than it's worth to change around. That and the Gear Ratios are a little wider than a normal T56. Find you a LT1 one.
Old 01-14-2009, 10:30 PM
jmd
jmd's Avatar
You need the offset shift lever from an f-body trans., the front case/adapter plate from a 94-97 F-body trans., And a 1993 F-body input shaft for a 2.97 first gear box. When you do the input / adapter plate, you'll want to verify / correct bearing pre-load. That's it. Don't worry about the lower tq. rating of the MN12 / 1993 F boxes.
And you really should have posted this in the manual trans. forum.
Old 01-15-2009, 12:40 AM
1996camaross's Avatar
not to be off topic but will a clutch disc from a 98-02 camaro work in my 96 camaro?
Old 01-15-2009, 12:42 AM
the_merv's Avatar
No. I haven't seen one that has worked yet.
Old 01-15-2009, 05:28 AM
Well in a race you don't really want to get into 5th anyway, that's overdrive. 6th is double overdrive. The point of the t56 is the fact that they hold a good power and can net you some really good gas mileage.
I really not sure what you mean by a lot of people have issues? My car now has 170k on it, I've changed the trans fluid once, I DRIVE this car HARD. Never had a issue with the trans itself. LT1 T56 with all the goodies should cost you $1200 max, a TKO trans is more expensive. The lowest rated TKO starts at $2k and that is just for the trans, its not coming with everything you would need.
Old 01-15-2009, 06:35 AM
the_merv's Avatar
It may be a little more for a LT1 T56..some of the prices for the T56's have been going up all over.
Old 01-15-2009, 10:03 AM
johnnyar15's Avatar
alright thanx, ill take ur advice, a friend of mine can get the t56 plus the entire conversion for 1000(he has the hook up), every where else it is atleast 1400!!!
Old 01-15-2009, 10:44 AM
white95z's Avatar
There is a Lt1 t56 swap kit in the market place supposed to be everything to swap for 1200 before shipping I believe its worth looking into. I was checking it out but its just not in my budget right now.
Old 01-15-2009, 10:50 AM
johnnyar15's Avatar
well a friend of mine works at a junk yard, and he gets great prices, so i gotta wait till he gets 1, then it is mine
Quick Reply: can i put a t56 from a 06 gto into a 94 z28?
