Pulling crankshaft sprocket and waterpump drive.
Old 01-15-2009, 10:27 PM
I8ASaleen's Avatar
Default Pulling crankshaft sprocket and waterpump drive.
Ok so, I got off the camshaft sprocket and took out the two bolts on the wp drive but now I can't get the wp drive nor the crankshaft sprocket off. I have a 3-jaw puller on the crankshaft sprocket with a bolt in place and a socket for the puller to rest against. I put the car in gear so it wouldn't rotate and interfere with the valves but even with an impact gun on the highest setting going forward it barely budged and now won't move. I put a thick coat of PB blaster on it just now and I'm gonna try it again in the morning but it just doesn't want to move. Any ideas? Does the wp drive require some special puller to remove it? I'm stuck.
Old 01-15-2009, 10:42 PM
shbox's Avatar
The crank sprocket should come off easily, if there is even pulling pressure on it.
Old 01-15-2009, 10:48 PM
JB_97ws6TA's Avatar
the crank sprocket should pop right off, I am assuming you have the cam sprocket off I hope, as for the water pump drive I just removed the retainer screws and used a brass punch to drive it out of the block from the valley
Old 01-15-2009, 11:16 PM
I8ASaleen's Avatar
It definitely feels like it's frozen on there so I coated it in PB blaster. The retainer came off easily like you guys are saying but this one just doesn't wanna move. Yes I do have the cam sprocket and the chain off the only thing on there is the crank sprocket itself. I'd like to not have to remove the intake manifold for the wp drive b/c I'm supremely broke and don't really have enough money to get this thing moving if I have to replace any more gaskets/whatever.
I may just have to borrow some Burnz-O-matic and heat it up.
Old 01-15-2009, 11:40 PM
moderate Z28's Avatar
I just removed my crank sprocket yesterday with a 3 jaw puller rented from advance auto. It was on there pretty good. Everytime I would pull on it after about 10 seconds one of the jaws would fall off from behind the sprocket and I would have to start over. On the 4th try it finally came off. You just have to keep at it, make sure the everything is centered and the jaws are evenly spaced for equal pressure. To me the hub was harder to pull off.
Old 01-15-2009, 11:44 PM
buffman's Avatar
there is a puller for the waterpump that comes in the LT1 Kent Moore tool kit. I don't see why you can't use a standard puller to do it.
Old 01-16-2009, 12:04 AM
I8ASaleen's Avatar
The hub was ridiculous to pull off, I had to keep going and getting longer bolts!
@Buffman, would a 2-jaw work? Is that the standard puller you speak of?
Old 01-16-2009, 12:07 AM
buffman's Avatar
the one in the kit is basically half a square. It's in the center. You can get an idea of how it works from looking at it.
Old 01-16-2009, 12:10 AM
I8ASaleen's Avatar
Gotcha, I'll head to the local parts store tomorrow to see if I can round something up.
Old 01-16-2009, 01:56 PM
I8ASaleen's Avatar
Well crap, went to like 3 different places and no one has anything like that. Looks like the intake manifold will have to come off. On another note a guy told me that the crank sprockets normally get frozen on there and the most guys take a chisel and just break it between the teeth, does that sounds feasible?
Old 01-16-2009, 02:11 PM
shbox's Avatar
A two jaw puller might actually be easier to hold on there and get to where it will pull straight off. You can always rap the face of the gear with a hammer. The vibrations may cause it to snap free. I just have never had one that would not come off.
Old 01-16-2009, 02:30 PM
sweet-94z28's Avatar
I pulled my crank sprocket off with a 2 jaw puller
Old 01-17-2009, 12:48 PM
I8ASaleen's Avatar
Alright, so could a slide hammer be used for the wp drive?
Old 01-17-2009, 06:46 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
On the water pump drive are you talking about the small splined piece? If so that should just pop right off.
Old 01-17-2009, 09:17 PM
I8ASaleen's Avatar
The part that attaches to the timing chain and actually drives the waterpump. Buffman posted a pic of the puller, but I don't have access to any kent moore stuff so I'm looking for a suitable puller.
Old 01-17-2009, 09:48 PM
OWN3D BY MY PROF!
You don't need a puller for the water pump thing if it is what I'm thinking of.
Is it the part is the bottom left. There's two of them in a plastic bag. It looks kind of like a socket.
Old 01-18-2009, 01:27 PM
I8ASaleen's Avatar
Well I'm trying to take off the thing that is pressed into the block and meshes with the back of the timing chain, it has a gear on it with alot of teeth that mesh into the gear on the back of the timing chain.
Edit: and EWwwww you put Fram on your car!
Quick Reply: Pulling crankshaft sprocket and waterpump drive.
