K&N FIPK tube adapter sucks
Old 01-19-2009, 07:43 PM
C_Rules's Avatar
Default K&N FIPK tube adapter sucks
I had my K&N FIPK for years works fine. However, the tube adapter that connects the actual platstic intake tube to the MAF does not fit correctly. I can't get the MAF housing end into the rubber tube where it needs to be. I can't get it deep enough for the worm clamp to actually grab it and it doesn't make a really good seal anyway. Does anyone else have this same problem? What else can I use to connect the two together?
Old 01-19-2009, 08:02 PM
ss.slp.ls1's Avatar
Home Hepot/Lowes.
Old 01-19-2009, 08:35 PM
C_Rules's Avatar
can someone say fernco lol.
Old 01-20-2009, 01:23 AM
96blackta's Avatar
Women shop at Lowes.
Try Home Depot. *grunts*
Old 01-20-2009, 05:12 AM
Counted Out's Avatar
It sounds like your trying to use the piece that is only for 93's - the K&N kit comes with a 4" adapter because 93's don't have a MAF. Since you have a 94, you should just be able to hook the intake to the elbow.
Hahahaa, I bought a Moroso CAI for a 94-97 and I needed to make it fit my 93.
Old 01-20-2009, 09:22 AM
94Z28rag's Avatar
Fernco made my K&N fit
Old 01-20-2009, 09:24 AM
MonmouthCtyLS7's Avatar
Never had a problem w/ any of the setups on my 2 LT1's....but yea its an easy fix...
Old 01-20-2009, 09:26 AM
C_Rules's Avatar
that may be the case. the MAF hardly goes into the rubber piece that connects the maf to the K&N intake tube. i had left it as is since i didnt feel any air escaping and when i got into tuning i chose to run in SD mode. now that i decided to tune the MAF sensor its aggravating me. i'll hit up Home Depot and get a fernco coupling. if it looks crappy then I just order a silicone turbo coupling.
Old 01-20-2009, 12:52 PM
Fbody4Ever's Avatar
yep, that piece sucks. A Fernco isn't a good solution for this particular setup either, a 4" will swallow the MAF and cranking down on a hose clamp to make it up is ghetto. You need a 4" to 3.5" coupler. 4" for the K&N and 3.5 for the MAF. I used a turbonetics coupler for mine, but there are others out there.
Old 01-20-2009, 03:36 PM
C_Rules's Avatar
fernco makes reducer couplings as well and they are way cheaper. of course the turbo couplers are glossy and better looking. looks or savings thats always a tough one.
Old 01-20-2009, 05:29 PM
Another solution is to go to Checkers or Pepboys and look at the stuff made by Spectre. They make pieces to make your own CAI and I remember the last time I was there they had couplers in all sizes and colors - I wish I would have seen those before I ghetto-rigged mine.
Old 01-20-2009, 05:51 PM
AChotrod's Avatar
I was lookinfg at those and didnt see a 3-4 coupler. The were all Import sizes ! If i remember right my old K&N came with 3"-4" coupler.
Old 01-20-2009, 07:40 PM
C_Rules's Avatar
I went to HD and picked up a fernco 4-3 coupler and it fits WAY better. I suggest that when you buy the kit throw away the adapter tube it comes with go to HD and pick up one of them for 10 bux. Or if you already had the kit forever like me just go out and buy it anyway. The whole MAF housing end goes into the coupler and a lot more of the intake tube as well. The pic below shows it:
Quick Reply: K&N FIPK tube adapter sucks
