What size o2 wire extensions
Old 01-26-2009, 02:02 PM
96Formula6spd's Avatar
Default What size o2 wire extensions
Hey i have long tube headers on my 96 firebird. My old o2 sensors are dead so i am replacing them and buying some o2 wire extensions. What length should I get. 12 inches or 24 inches?
Old 01-26-2009, 02:24 PM
lt1z28camaro's Avatar
If you already had extensions why not get same length? Kinda varies by headers but I went with 24's jsut to be safe and zip tie them so they don't hang/drag but 12's would probably fine...lol sorry i'm not much help...i just made sure i had long enough extensions so i didn't have to order them send back and order again..
Old 01-26-2009, 03:00 PM
Elliott's94Z's Avatar
My 12inch ones were just barely long enough. 24's might be a safer route to go.
Old 01-26-2009, 03:34 PM
I did not have extensions. They were the cut and add method from pacesetter. Now I just want to add extensions looks like 24 inches will work better.
Old 01-26-2009, 04:03 PM
TABBED 5.3's Avatar
I went with 2 24" extensions from racetronix, price wasnt too bad. I also have pacesetter headers.
Old 01-26-2009, 04:23 PM
Raven97's Avatar
I am running hooker longtubes and I only had to extend the wires on the driver side about 6 inches. so I would say that the 12 inch extentions would be enough.
Old 01-26-2009, 08:53 PM
blkZ28mara's Avatar
Do lt1's use the flat or square connectors?
Old 01-26-2009, 09:02 PM
Flat 4 prong is what I'm running
Old 01-26-2009, 09:04 PM
Raven97's Avatar
the flat ones are the upstream and the square ones are downstream from the cats, at least thats how it was on my 97 WS6
Old 01-26-2009, 09:18 PM
dilatedpeoples28's Avatar
flat for pre cat
Old 01-26-2009, 10:30 PM
blkZ28mara's Avatar
Alright thanks guys
