how did are lt1 xpipe true dual set ups than ls1?
Old 02-22-2009, 03:22 PM
integraxtc's Avatar
Default how did are lt1 xpipe true dual set ups than ls1?
botched the title:
How different are lt1 xpipe true dual setups than ls1 set-ups?
this is an ls1: See how the front of the setup bends to meet the driver side
The reason I ask, is because, I was thinking about getting a universal Pypes xpipe kit, and they obviously don't have that bend. I was just wondering how much customization the pypes xpipe kit would need.
http://www.jegs.com/p/PYPES/1159309/10002/-1
and also, how would it be to get the pypes "mounts in drive shaft tunnel" kit?
Old 02-22-2009, 03:28 PM
96lt1m6's Avatar
not much and can be modded just a bit to fit!
Old 02-22-2009, 03:43 PM
integraxtc's Avatar
so is it pretty much just straight ends to meet the headers? Or is there a little bending to meet the headers?
Old 02-22-2009, 03:45 PM
96lt1m6's Avatar
a slight amount of bending will get the job done.
Old 02-22-2009, 04:25 PM
speed_demon24's Avatar
Mine are pretty much straight back from the headers unlike the LS1 setups.
Old 02-22-2009, 07:14 PM
integraxtc's Avatar
yeah, I remember seeing your set-up.
Old 02-22-2009, 07:19 PM
Green3spd's Avatar
both of those set ups look nice.. any exhaust shop can bend some piping for you if it comes to that..
Old 02-22-2009, 08:39 PM
hyperzone's Avatar
My x-pipe setup was intended for an LS1. Here's what I changed. The first pic has a part circled... that is the extra piece the exhaust shop made for it to work.
Old 02-22-2009, 08:55 PM
James Montigny's Avatar
You'll just need a short piece of 3" pipe with a flare to fit over your collector.
That is, assuming you are not running flanged headers.
Old 03-09-2009, 10:29 PM
913MOTOR's Avatar
So its safe to say, if TSP supplied a right side pipe instead of the two normal left side pipe, that it would work perfect for an LT1 car?
Old 03-10-2009, 11:43 AM
Vicious95Z28's Avatar
Looks like the rumbler would prolly be extremely close if you have Kooks headers, they kick out 15*. I had Spintech bend me the piece that I needed to work with my headers.
James
Quick Reply: how did are lt1 xpipe true dual set ups than ls1?
