View Poll Results: Do you mind the pass. floor hump?
YES! I hate it! What the hell was GM thinking?!?
19
28.79%
Nope, dont care since I'm on the other side...
30
45.45%
Kind of, but I dont think about it much.
17
25.76%
Voters: 66. You may not vote on this poll
Passenger Floor Hump Removal
Has anyone ever attempted to get rid of the passenger side floor hump? Is it impossible to do? I haven't seen under my carpet for a long time so, I cant remember if there is anything major in the way that would keep someone from just beating it flat with a BFH.... Any thoughts, facts, or photos from anyone that has also pondered this?
its prob there for a reason, if they would have noticed there was no point of having that hump there they would have not put them on the newer years. so for example the 93LT1;s there OBI with a 4L60 transmission, and the 94+came 4l60e and 95+came 4l60e and OBII..the 93s where pretty much test mules....so the hump must be there for a reason. if not they would have made the cars different with no hump
I believe it is only for the catalytic converter to fit under the car nicely in a stock exhaust setup. I dont have this and I'm sure many others dont either so, there's no reason for the hump in that case. I've thought about it a few times but, was wondeing if anyone has modified this already or nobody else cares about it.
carpet is not a concern. It can easily be heated and pressed down. If that didn't work, a screw or two would fix it. I've been a passenger enough times in these cars to wish it wasn't there. Oh well,...
cut it out and weld a piece of steel in. yeah its for the cat meow!!! the body of the fbodies are all the same 93 up they just change the fenders right? and lights.
it has been done and posted about on LS1tech. Try searching the Paint & Body forum, Appearance, and maybe Drag racing. there's a post somewhere here that had good pics of the process.
The trans crossmember has to be modified as well as the part of the formed "framing" it bolts to on the passenger side.. it all occurs on the underside of that hump. Other than that it is pretty much straight forward. The stock carpet will even sit down nice going by the pics that were posted.
Correct - put in for the cat...
Passenger Side Hump is to F-Body
as
*** Inches From The Ground is to Corvette
I say leave the bitch, you're in the drive seat anyways, so who cares Passengers should be more worried about the lack of things to hold onto for dear life than a hump in the floor that is under their knees and doesn't affect their legroom any unless they're a Mini-Me sized midget.
That damn hump must be removed.Im so tired of my ol'lady bitchn about it that Im about to run her *** over.But the trim's to good so if I can get rid of the hump maybe she'll shut up for a second untill she finds something else to bitch about....
You could always add more height to the rest of the carpet so that it is flat and nobody notices... I don't think it is really worth the effort in my opinion. Maybe you should change your driving style so that the passenger isn't worrying about a bump in the carpet
